Best H11 FOG LIGHT BULBS Suggestion please?
330_2_S3 Feb 4, 2010
  1. 330_2_S3
    330_2_S3 Member
    243
    As stated in title, Just wondering if you guys/girls have any suggestions as to what are the best resonable priced bulbs and emit the XENON type look to match the main beams?
    Did a search and couldn't really find nout.
    There used to be a thread on here where there was a "group buy" for different light bulbs but since the change over in appearance, I can't find it on the search :(
    Cheers in advance
  2. 330_2_S3
    330_2_S3 Member
    243
    No one replaced these at all with better ones?
  3. S.
    S. Save the manuals Team Ibis TFSI Owners Group Audi S3 quattro Manual
    2,027
    553
    think that PIAA makes them.
  4. 330_2_S3
    330_2_S3 Member
    243
    Have you got these personally? If so what do you think of them?
  5. Synchromesh
    Synchromesh :-)
    98
  6. S.
    2,027
    553
    no i don't have them. i actually think that fog lights are like that for reason. but i think madalex had them on his s3 (use search for pics), and it looks quite good.
  7. 330_2_S3
    330_2_S3 Member
    243
    Ok cheers for the info guys.... I think there needs to be thread created in the "Look her first" sticky with this sort of thing as I searched and didn't find anything :(
  8. smudge_don
    smudge_don Active Member
    2,944
    You won't find any normal bulbs that are the same as the xenon beam as they're obviously not xenon bulbs
    Only way would be to install an aftermarket HID Xenon pack into the foglights
  9. 330_2_S3
    330_2_S3 Member
    243
    I wasn't after xenon beams I just wanted matching colours rather than the stained yellow look which looks off key with the xenon set up...
  10. AuldReekie
    AuldReekie Member
    770
    As S. has mentioned I think fronts fogs are meant to be off-white (different temp) to reduce the reflection and enable you see, and be seen, easier in fog. For the amount of time it is foggy in UK (especially London) I can't see the point...I mean it's not like you will be driving about with them on when it's not foggy.
  11. 330_2_S3
    330_2_S3 Member
    243
    Yeah this is true, but one of the bulbs has blown and since I need to replace one might aswell do both and match up with the xenons while I'm there
  12. AuldReekie
    AuldReekie Member
    770
    Gotcha now. Well I used these guys for PIAA DRL and side replacements, maybe they can advise better. I am not sure I have seen many threads on here about swapping out the foggies, but these ones on the link below are H11.
    http://www.priracing.com/product.php/2209/34/piaa-h11-xtreme-white-bulbs--pair-
  13. 330_2_S3
    330_2_S3 Member
    243
    Cheers mate will look into it that bulb out warning light is pi**ing me of hard!!!!!
  14. gixxer600k4
    gixxer600k4 Member
    692
    gotta be carefull though because if you fit the bulbs that have a blue coating and they say they give a whiter light and its brighter, yea it will be whiter and be more of a match to that of a xenon bulbs, the lights will be rubbish, the blue tint traps in a lot of light and temperature. ur best off fitting osram night breakers, wont give you a good match but will be slightly brighter and you get better vision. the extreme white ones you get are purely for show.
    the nightbreaker have a light blue tint at top and bottom of bulbs leaving a clear section in the middle, it moves the temp to about 2700k to 3000k but keeps the performance of bulbs, where these extreme white ones move the temp to like, 4500k
    http://www.autobulbsdirect.co.uk/h11-bulbs.html
