Best Fuel additive ?
mattyboy199 Mar 3, 2008
  1. mattyboy199
    mattyboy199 Well-Known Member
    1,885
    Whats the best stuff to raise the Octane rating. I ve heard the stuff in Halfords is a load of rubbish.
  2. 1animal1
    9,976
    i saw a test conducted on TV where they setup a Rover K series engine under strict conditions, trying all of the 'main' additive brands...and it showed alomst no change...infact, a couple gave negative results!!
    Not sure what it would do on this engine with it being turbo'd and uprated..... I am actually apprehensive about touching any additive now after seeing that
  3. S3 Rav
    S3 Rav Well-Known Member
    2,820
    29
    yea that was on 5th gear and they said that all additives actually gav a decrease in power by 2%! id leave the additives and just go for the optimax!
  4. simch
    simch Active Member
    2,028
    Millers CVL and CVL plus are octane boosters that do seem to work, as well as Silkolene Proboost, but be aware of the possibilities of MMT fouling when using them. (dirty plugs etc)
    But you would need your car mapped to suit any increase in octane to be able to advance the timing in the midrange for more torque. On a stock engine you would see little benefit apart from perhaps some increased "smoothness".
  5. S3 Dave
    S3 Dave Now running on Heavy Oil
    432
    Try BP ultimate "102" if you can find it...........
  6. ANDYTQ
    ANDYTQ Well-Known Member
    1,178
    101
    Millers cvl works for me with ignition timing altered with sps3 to suit,only used a couple of times a year to avoid cat damage,millers normal octane boost can be used all the time.
