best dump valve for a 1999 audi a3 quattro
bansheeboyo Dec 21, 2008
  1. bansheeboyo
    bansheeboyo Member
    201
    Hi guys would like your opinion on what the best dump valve is for a standard 1999 audi a3 1.8t quattro,i have been looking on the net but can only seem to see baiiley dump valves are these any good i was looking for hks but unsure if they will fit,new to the whole car thing.
    thanking you in advance
    scott.
  2. Ess_Three
    Ess_Three Active Member
    5,383
    12
    Don't fit a dump valve at all...it'll only cause your engine Management problems as it gets confused as to where the metered air has gone...leading to longer lag between coming off the throttle and getting back in it, slightly decreased performance and sounds utterly Chav (in my view).
    What you need is a Divertor Valve, so it keeps the dumped air in the system.
    Forge make some good Divertor Valves.
  3. A3ster
    A3ster Member
    87
  4. DPM
    DPM Site Sponsor Site Sponsor
    4,917
    179
  5. S3mad
    S3mad Dark Knight
    946
    Dont get a dump valve that will give u no advantage and you will just sound like a fool ...
  6. s3_jon
    s3_jon New Member
    As said by Damian and others you dont want a 'Dump Valve' as such, the Vag 1.8 turbo engine uses a recirculating air system, this means that the air that would be dumped has allready been measured and accounted for by the ecu. You need to fit a recirculating diverter valve, this way the engine gets its air back just like stock and doesnt run rich and splutter on every gear change.
    I can only speak for the Forge 007 that has allready been mentioned as i have one in my s3 and its solid as a rock. If you want the dump valve noise then fit a cone filter at the same time and you will be able to hear plenty of wosh on every gear shift under boost.
    Damian - I will be coming yourway in the new year to get a DV cold side relocation kit for my S3, do you know if you still get the above mentioned wosh on gear changes or does that tend to go away as your dumping less air between gears?
  7. DPM
    4,917
    179
    With a induction kit you will get a nice noise from the 007P but you do get more from the Splitter valve, but we still prefer the 007P.
    Damian @ DPM
  8. Yaz
    Yaz Member
    225
    Are these splitter valves (Forge) ok though? I want one of these, but not if its going to cause me problems.
  9. DPM
    4,917
    179
    They don't cause problems and do give you more noise then what the 007P's do, you'll be fine with it and it's a great valve, just personal choice that we prefer the 007P's.
    Damian @ DPM
  10. Yaz
    Yaz Member
    225
    Ok cool, thanks for confirming that. I get some sort of satisfaction from the noise of my gases dumping!:)
    I want to buy one of these asap, just gotta choose somewhere...
    RB S3 likes this.
  11. @unger
    @unger New Member
    15
    007p reversed is loudest whoosh sound possible iv found with 1.8t. Does get boring though LOL
  12. <tuffty/>
    20,813
    3,665
    ...although this is not the way its supposed to be fitted and can allow the DV to be forced open under high boost....
  13. Westy
    Westy Well-Known Member
    17,440
    1,097
    Reversed 007P sounds like a load of poo if you ask me. More of a high pitched chirp then a whoosh noise.
