Best disc and pad set up for standard brakes???
aps55 Aug 18, 2011
  1. aps55
    aps55 Member
    54
    Hi there I was just after some suggestions on what the best disc and pad set up would be for my A4 avant Tdi 54 reg.
    I don't want to pad top price for genuine audi discs and pads when I'm sure there is either better for the money or at least as good combinations out there. I just have the standard brake set up and am not looking to up rate to S4/RS4 brakes just a set up I can use with my standard calipers. And obviously the best place to buy them from, I will fit them myself so not bothered about garages for fitting.
    Thanks for any suggestions
    Aaron
  2. quattrojames
    14,068
    585
    I've always found oem discs and pads a good option, granted I've not tried all the aftermarket options, but the combination of minimal pad dust and hardwearing discs works for me.
    Have you had a price from a motor factor? They're not normally that expensive either depending on where you go. Try Eurocarparts or TPS.
    Sent from my BlackBerry 9700 using Tapatalk
  3. aps55
    aps55 Member
    54
    To be honest I haven't looked at OEM discs and pads just because I though they'd be over priced being audi. I'll look into it. Thanks
    Aaron
  4. Tooks
    Tooks Active Member
    753
    30
    I'm running a set of Brembo OEM discs and Jurid pads from GSF, had them on about 6000 miles, and no complaints from me.
    Not very expensive either, £83 + VAT according to the receipt I just dug out.
  5. swarcup
    swarcup Well-Known Member
    1,326
    40
    ive fitted brembo max discs and brembo pads cant fault the braking although with the discs having grooves they do throw out more dust. They are deffo better than oem as the first time i braked from speed i wasnt ready for the difference they made and shot forward in my seat. Paid 96 quid for the discs and 50 quid for the pads
  6. aps55
    aps55 Member
    54
    Thanks Guys!
    I'll have a trip round to my local GSF as it's only a few miles down the road. :idea:
  7. Phil-UK
    Phil-UK New Member
    23
    Can you report back your findings when you get prices? I want to do the same so interested in what you find out.
    Regards, Phil
  8. aps55
    aps55 Member
    54
    Will do!
  9. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group s tronic S-line owners group
    4,005
    765
    I find padig To be very good also eurocarparts have a 25% online discount.
  10. aps55
    aps55 Member
    54
    Will look on euro car parts website then. Cheers
    Just spoken to GSF.
    Front discs Brembo= £26.95 each + VAT
    Front OEM pads= £29.50 for the set +VAT
    Rear Brembo= £17.55 each +VAT
    Rear Pads OEM= £10 for the set +VAT
  11. aps55
    aps55 Member
    54
    Euro car parts comes in at £214.66 for front and rear discs and pads (Pagid)with their 25% discount.
    GSF comes in at £137.70 all in.
    Correction on the front pads above, they are £14.95 for a set not £29.50
    That's still a massive saving at GSF. Bu I'm not sure what size discs that price is for as I don't know what mine are yet.
  12. Tooks
    Tooks Active Member
    753
    30
    My discs were 288mm, I didn't get the cheapest pads, so £86 +VAT seems like it's still the price for the Brembo's and better pads.
  13. Phil-UK
    Phil-UK New Member
    23
    Thanks for that, not too bad a price if doing yourself. All new discs and pads for under £140.
    Regards, Phil
  14. aps55
    aps55 Member
    54
    No problem.
    Yea I was surprised too, I didn't expect Audi parts to be as cheap as that.
  15. jbcalvin
    jbcalvin Member
    691
    21
    I did mine all round earlier this year, had MAJOR problems trying to get brembo from GSF, after waiting 3 weeks, went to Euro and got Pagid stuff instead, recommended as being as good as if not better than OEM by my local independent (ex Audi master tech)....
