Best Cutting Compound for Audi Paint?
a6_chris May 26, 2013
  1. a6_chris
    a6_chris Well-Known Member
    1,883
    159
  2. Amason007
    Amason007 Member
    116
    41
    Hi Chris,
    I'm using the same combination. I no expert but managed to go from this
    to this on my bonnet recently.
    Are you giving the compound time to breakdown and do its work? I needed to use quite a lot of pressure and kept going until the compound has almost vanished, just a light haze remained.
    Although these are only swirl marks and not scratches. But if i had a scratch, i would work on that area for longer.
    Hope that helps?
    Andy
    scotty76, gupsterg and a6_chris like this.
  3. ajax1976
    ajax1976 Well-Known Member
    1,253
    647
    As above polishes need to break down to work but only thing I would suggest is that it takes a long time with a DA polisher, rotaries are better suited to hard paints like Audi.
    Menzerna polishes are excellent on harder paints too though if you fancy giving that a try first.
    a6_chris likes this.
  4. a6_chris
    1,883
    159
  5. RS3Shuk
    RS3Shuk Daytona Grey RS3
    13
    Just did my M3 with Megs DA and microfibre system. Worked well tbh. I also did my X5 yesterday (albeit it only had light swirls) with All in One (AIO) Britemax. This was applied with the same microfibre polishing pads and the results were really good. I will be using AIO Britemax alot more from now on.
  6. Amason007
    Amason007 Member
    116
    41
    Chris,
    pop over to Machine Polishing - Detailing World
    Lots of info there.
    Andy
