Best coilover for a4 b6 salon
Stusa4 Jun 27, 2013
  1. Stusa4
    Stusa4 New Member
    Are pro sport coilovers any good no knocking or anything ???????????
  2. hades-
    9,481
    646
    how much are you wanting to spend ?
  3. Stusa4
    Stusa4 New Member
    Not a lot got fk streets on at the mo an thay r **** thay knock an make loads of noise
  4. hades-
    9,481
    646
    iv used FK quite a few times and never had noises
    i think there quite good for a budget coil
  5. czm
    czm Member
    266
    19
  6. Stusa4
    Stusa4 New Member
    Thay look mint but a bit to much money mate have u any experience with pro sports an do thay come with helper springs ??? V
  7. deano1978
    deano1978 different gear
    713
    81
    this is still a raw point (knocking noise) as some budget coilovers dont make the knocking noise. Ive the mid priced fk silverlines... Installed without helper springs....still makes a knocking noise.
    So put them back on...STILL a knocking noise!!
  8. Mike.M
    Mike.M Well-Known Member
    2,509
    170
    Knocking usually comes from the front driveshaft hitting the chassis leg due to being that little too low.
    Some combat it with notching the chassis leg but this has become an MOT failure recently due to messing with the cars structural integrity.
  9. deano1978
    713
    81
    Tell me more about this fix?
    As this is what i think is causing the knocking noise,.
  10. Mike.M
    2,509
    170
    If you look up "chassis notching" it should explain everything.
    Basically taking a notch out the chassis leg to allow the drive shaft to move higher up for better lows.
