Best (bright white) bulbs for headlight upgrade and sizes please? facelift 8L S3
chris-edin Nov 20, 2011
  1. chris-edin
    chris-edin Member
    116
    Hi folks.
    What are the best bright white bulbs to stick in the head lights? I'm after the same bright white light as my Xenons from all the bulbs.
    Looking to change
    main beam bulbs - Philips diamond vision maybe?? What size?
    side light bulbs - suggestions? size?
    indicator bulbs - i'll stick in silver visions, size?
    fog bulbs - suggestions? size?
    As it's a bumper off job i'll do the lot in one go.
    Help appreciated, cheers.
    Chris
  2. Gops
    3,198
    666
    I think the headlights on the standard s3 are 4.3K. 6K bulbs would be nice and white! I wondered this too as i think the lights are abit dim! As for the sidelights, i think they are 501's or ba9's.. im not sure, either way i'd recommend LED ones. You can actually get LED indicator lights too!
  3. chris-edin
    chris-edin Member
    116
    Hi mate,
    Not changing the xenon's, just the rest of the bulbs in the headlight's.
    Chris
  4. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    If you ever want to change your xenon bulbs get 6000k, they are very white and look so much nicer than standard! (although i have 8000k). The type of bulb is called 'D2S', so search for D2S 6000k if you ever do fancy a change.
    For the sidelights you need '501' type bulbs and you should get xenon white led's. I got the following before on my car and they are so bright they pretty much light up the whole lens! They're pricey compared to others but they're bright xenon white and the brightest you can get!
    Go here, www.ultraleds.com - Go to search and paste this number in the box - U50115W
  5. colicabcadam
    colicabcadam Guest
    sorry to burst your bubble, but 4300 is the brightest colour you can get, google it !
  6. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Very true, but look ****e
  7. rhubarb4
    rhubarb4 Certified Audi nutter Gold Supporter Team Silver Audi S3 quattro
    1,754
    188
    Yep +1 he is correct as for the lights strangely the lower the K the brighter the light
  8. Inertiauk
    Inertiauk Active Member
    575
    29
    Its not strange, higher K (colour temp) means more yellow removed, not more white added, hence light is removed.
  9. colicabcadam
    colicabcadam Guest
    why do people dislike posts when they are wrong? a guy asked what the brightest white was - which is 4300k, not your suggestion of 6000k which has a hint of blue in it, oh well, spit your dummy out like a child then......
  10. Gops
    3,198
    666
    Sorry mate, I only just seen that now.. I thought I pressed "like"! Sorry dude! Never really knew that as I seen some really bright white lights! So if I got 6000k it'll only just be whiter but no brighter than 4300k?
  11. colicabcadam
    colicabcadam Guest
    lol - oh well - i am just in a bad mood this morning lol!!!
    4300 is basically the brightest colour with no visible yellow in it, 4000 would have a slight hint of yellow, 6000 is not whiter than 4300, it's got a hint of blue in it
    i admit that the higher colours look better (i have 8,000k on my ducati), but they produces less usable light - the standard set across the board was 4300, but as you can see, 4700 is a good colour too
  12. chris-edin
    chris-edin Member
    116
    Thanks for the post guys.
    Think I possibly mislead you all though.
    I want to leave the standard Xenon bulbs and get bulbs for the high beam and side lights which give a similar light to the Xenons.
    What bulb fitment are the bulbs for high beam? H7?
    What fitment would the indicator bulbs be?
    Thanks again
    Chris
  13. chris-edin
    chris-edin Member
    116
    Hi mate,
    The description lists the following so maybe best to stay away from these.
    Plastic body- not to be used close to a heat source i.e. headlight
  14. colicabcadam
    colicabcadam Guest
    this is what they are on an rs4 minus the HID bulbs - i believe they are the same across the board during that period
    High beam headlamp
    H7
    Parking light
    2886X
    3457ALL
    Front turn signal
    2827
    3457ALL
    Rear turn signal
    7506
    Tail light
    7528
    Stop light
    7528
    High mount stop light
    2825
    Fog/Driving light
    H7
    License plate
    6418
  15. chris-edin
    chris-edin Member
    116
    Spot on, thanks buddy :)
  16. colicabcadam
    colicabcadam Guest
  17. chris-edin
    chris-edin Member
    116
    Good buy mate, might just grab them then, give them a go, the xtreme vision bulbs are pricey.
    I don't like the fried egg look of the indicators, is it possible to change the high beam / side lights without wipping the bumper off?
    Chris
  18. colicabcadam
    colicabcadam Guest
    yea - it is a squeeze but from what i remember you can - the side lights are the worst ones to do ! fogs are the easiest!
  19. flubbachany
    flubbachany New Member
    Any recommendations for LED indicators and LED brake bulbs? I purchased a set of CANBUS LED indicators (front and rear) as well as CANBUS LED brake lights, but the car still didn't like them! Got the indicators hyperflashing with them installed (everything lights up, but the flash like mad), and the brake light throws a fault on the LCD display, but lights up as well.
    Cheers!
