Best and cheapest place to get S3 TIP
Andrew@A.L.D Jul 23, 2009
  1. Andrew@A.L.D
    3,879
    617
    As above, Are they all the same from the BAM to the APY?
  2. Dani_B19
    9,382
    403
    No the oem tips are quite different between the non esp APY and BAM engines, have alook at my oil catch tank thread to see the difference between the two, although the sfs one if aftermarket the design is very similar to a oem BAM tip.
    As for the best place id say sfs but thats only because i get a really good discount, give them a call and ask for either lee or justin, if you ask nice enough theyll knock you sumet off.
  3. DPM
    DPM Site Sponsor Site Sponsor
    5,065
    224
  4. S3 Rav
    S3 Rav Well-Known Member
    2,825
    30
    damian do you offer as.net discount?
  5. DPM
    5,065
    224
    On the Forge TIPs we do half price delivery.
    Damian @ DPM Performance
  6. s3_kev
    s3_kev Stage2'd!!!!!!
    2,002
    23
    make sure you have esp other wise you will have to follow dani's link to modifiy the n75 and bits to fit the tip,
    i brought mine from ths performance really good quality with a metal srtenghtening bit all the way through the tip to help stop it expanding and collapsing also there other boost pipes are made in the same way, cheap to think the tip was around £85
  7. S3 Rav
    2,825
    30
    ive heard of ths. how good are they?
  8. s3_kev
    2,002
    23
    seems ok to me i dont really like using inferiour parts and was sceptical but there really good quality, tip fits perfect
  9. S3 Rav
    2,825
    30
    does anyone know how much ply the forge is?
  10. Dani_B19
    9,382
    403
    5ply same as sfs, most others are only 4ply
  11. S3 Rav
    2,825
    30
    ths is 4 ply
  12. Andrew@A.L.D
    3,879
    617
  13. s3_kev
    2,002
    23
    but depends wether you have esp???
  14. s3_kev
    2,002
    23
    but has a 5th ply of metal core so much better imo
  15. Andrew@A.L.D
    3,879
    617
  16. Andrew@A.L.D
    3,879
    617
    No i don't. just done a search to find out what it was
  17. s3_kev
    2,002
    23
    ok in that case you can fit the tip but it needs some alterations to fit it, dani_b19 has done his recently and theres a thread on here recentlyshowing you what needs altering but by all accounts it made a big improvement on his car
  18. Dani_B19
    9,382
    403
    Like kev said it did take some altering but as long as your compitent then its easy and the end result is so worth it mate, our oem tips are so restrictive, gis an email if you need a hand or parts sizes etc.
  19. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,249
    2,072
    Andrew have a look at the stickies for info please
  20. Andrew@A.L.D
    3,879
    617
    Thanks voorhees
    I've very sure i can sort it being a run a fabrication and engineering company lol
    Just leaning about Audis and S3
  21. S3 Nattie
    S3 Nattie Quattro ist für sissies
    1,599
  22. voorhees
    16,249
    2,072
    WoW
  23. Dani_B19
    9,382
    403
    You are a bitch some times! Lmao.
  24. Ess_Three
    Ess_Three Active Member
    5,383
    They are?
    On an S3?
    I don't think so...and I got precisely nothing from changing mine...so it can't have been 'so restrictive' at all!
    I don't see how they are....the hose tapers from MAF size to the outer size of the turbo inlet casting - which is itself larger than the compressor wheel...so there is no restriction there.
  25. Dani_B19
    9,382
    403
    Im not talking about the amk/bam tips glen i was refering to the oem tips on the non esp s3, if you've ever had a look at one then they are restrictive but upgrading the tip on a amk/bam engine would yield little to nothing.
    Although SFS do quote their tip tobe 16% larger than the oem tip and have a dyno graph showing an increase of 5Bhp and 5Lb/ft but we all know dynos can be fudged.
