Bentley splits on 8p s3
S3 syc Jan 22, 2013
  1. S3 syc
    S3 syc Active Member
    154
    29
    Just after a bit of advice will I be ok with 9x19 bentleys et 41 on my 8p s3 I'm being told the offset is wrong although I'm currently on Helios which are et45 or 46 but only 8.5 wide will the bentleys be much different figment wise
  2. BradHatton
    BradHatton Member
    394
    13
    If you run 225/35/19 you should be fine, go 215 if you want abit more stretch.
    I'm running the 5 spoke bentleys which are the same spec and they sit perfectly.
  3. garuf
    garuf Member
    130
    Im running some 9x19 et 52 s6 wheels with 5mm spacers a little tucked with no issues, so like BradHatton said they will sit flush and perfect. I'd say your probably better going with 215/35/19 if you don't mind a bit of stretch.
