Bent arm ?
Effect Feb 21, 2010
  1. Effect
    Effect Member
    469
    The arm in the pic that is bent goes to the front headlight level sensor, what I would like to know is how will having a bent arm like this affect the headlight leveling ?
  2. ALPINE
    3,093
    MAYBE IF YOU GOT A HEAVY LOAD IN THE BACK, THE FRONT GOES UP, AND THE SENSOR ATTACHED TO THIS ADJUSTS YOUR LIGHTS SO YOU DONT BLIND EVERYONE?
    soz caps didnt look up till i done!
  3. rossbrownlee
    rossbrownlee Ross_S4
    719
    The arm on the rear suspension is straight, the arm on the front suspension is meant to be bent. don't panic.
  4. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,297
    373
    yeah, was looking at mine yesterday when replacing a broken wheel arch liner. Yes its supposed to be bent, unless mine has somehow bent in the exact same way as yours. BTW, is the wheel arch line supposed to be a SOAB to get in out?
  5. ALPINE
    3,093
    did i just read this wrong or is the geeza asking why the bent shaped arm would have any effect on the head light leveling?? i would of thought its obvious the arms meant to be that shape no??
  6. Alex C
    3,297
    373
    Yes it is meant to be that shape. But he was worried that it was supposed to be straight and had somehow become bent, in which case the headlight leveling sensor would be misinterpreting the position and level of the car.
    However, it supposed to be straight, so its fine
  7. ALPINE
    3,093
    ahh i see... i think ill lay off the fanta!
  8. Effect
    Effect Member
    469
    Yeh i thought it was meant to be straight like the rear one.
  9. Dani_B19
    9,365
    399
    Where are the arms located exactly?
  10. Carl Gibson
    Carl Gibson Member
    35
    On the passenger front side, had a look at the car earler and the arm is bent on mine too...
  11. rossbrownlee
    719
    There are two sensors, one on the front nearside suspension and one on rear nearside suspension.
    There is a bracket on the chassis with the sensor screwed to it. The sensor has a plastic arm on the side which is bolted to a linkage rod with a balljoint at each end, this drops down to the lower control arm and is bolted on there.
    If you turn your steering hard left and look in the nsf wheel well you will see the front one. At the rear the best way in to it is to jack up the nsr corner, although you can crawl about and see most of it with the car on the deck.
  12. Dani_B19
    9,365
    399
    Nice one mate.
