Benjamins S2000 air filter mod.
BENJAMIN Apr 29, 2011
  1. s3gazz
    s3gazz Well-Known Member
    1,376
    99
    or i well dont no if to go for it and sell my jetex mapping i9n a few weeks what do i do
  2. paultownsend
    paultownsend Member
    140
    @jardo. Do you have experience with the creations tip? Most others say its good (half price of forge).
    Is it just where it reduces in diameter going in to the 90' bend before the turbo?
  3. Prawn
    11,355
    3,196
    the creation TIP reduced very early on Paul, the forge one is 70mm at the top and gradually tapers down, only reducing fully at the very bottom where space is ultra tight.
    The creation one is 70mm at the top (for the MAF), then reduces gradually to the first bend (near the DV port) but from here down it's ALL tiny to the turbo. Holding one or the other in your hand you often won't spot the difference, but get them both together side by side and it's really obvious!
    I showed an S2000 owner at Donington my air filter yesterday, he honestly couldn't believe I was running it, and was even more shocked when I said it was happily producing 330+ bhp with that filter on there!
  4. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,183
    This should explain all.
  5. paultownsend
    paultownsend Member
    140
    Poop. So almost as restrictive as the OE tip then?
    forge have a seconds shop on ebay. Nothing for the AGU though :(
  6. Prawn
    11,355
    3,196
    AGU / AUQ tips are fairly interchangable to be honest mate, just the position of the DV and PCV swap over, nothing that's not easily fixed, or not an issue at all if you run a catch can.
  7. paultownsend
    paultownsend Member
    140
  8. Prawn
    11,355
    3,196
    looks like the same sort of thing to me, looks thin at the bottom compared to forge.
  9. paultownsend
    paultownsend Member
    140
    I lie. AGU tip in the Forge outlet for the same price of a creations TIP.
    It says its a B class item as has marks on the Forge logo so can't be classed as new!
  10. Prawn
    11,355
    3,196
    get it bought man!!
  11. paultownsend
    paultownsend Member
    140
    Done. The girlfriend treated me. This and the s2k filter. It's going to sound sweet!
    Do you think with the filter as close to the wing as possible with the tab on the filter zip tied to the wing tab, and also the 5-ply silicone tip, it will be secure enough as not to upset the maf?
  12. S3 zombie
    S3 zombie New Member
    19
    Has anyone fitted this on the s3 combined with the heat shield that bill supply's with his b5 tip? Ive just noticed the neck on my jetex has started to crack so will replace with one of these if theres enough room to keep the heatshield..
    Phil
  13. Euro_man
    Euro_man New Member
    23
  14. paultownsend
    paultownsend Member
    140
    that looks the same mate just a different colour. id try just phoning up a local auto factors that sells parts. try a japenese specific place.
  15. WorkInProgress
    WorkInProgress Member
    253
    When doing this on a non S3, there's an air feed coming from the inner wing that fed the airbox. Keep or remove?
  16. Squirrelofdoom
    Squirrelofdoom Member
    671
    23
    same on an S3 mate, I took it off
  17. paultownsend
    paultownsend Member
    140
    Jesus Christ the thing is loud. Initial thoughts are its lost some torque in lower revs. I'm sitting in the fence. Il test IAT's and maf readings tomorrow
  18. WorkInProgress
    253
    I'm fairly underwhelmed with mine to be honest, I'll give it a few days and see if it grows on me. Probably just my imagination but seems to have made my dodgy idle issue worse
  19. WorkInProgress
    253
    I thought that too, will go over all connections tomorrow to ensure they're all nice and tight
  20. paultownsend
    paultownsend Member
    140
    I just don't think our tiny blowers need them.
  21. Westy
    Westy Well-Known Member
    17,440
    1,097
    Trust me they do. On a K04 I registered nearly 10 extra BHP on dyno back to back tests between a smoothed stock airbox and a jetex cone filter. The cone will definitely improve performance.
  22. paultownsend
    paultownsend Member
    140
    I only have a k03 though!
    10hp is a great peak gain. But to me it's taken away something at the bottom to give to the top.
  23. Westy
    17,440
    1,097
    I do think a lot o these mods play with your mind a bit. It will be so difficult to notice much change on the road unless it was a significant amount of torque/power that was being lost. The first thing that I noticed when getting a bigger TIP was the power delivery was smoother low down but revs would climb easier up top so it is possible that the filter would do this. If you do put the stock airbox back on and you can do some VCDS logging it would be good to see what the differences are.
  24. WorkInProgress
    253
    Just back in from a wee blast as the lack of torque thing was bothering me. To be honest I think it could've just been my imagination earlier, does feel a bit livelier, certainly no worse than with the airbox on.
    Westy likes this.
  25. Squirrelofdoom
    671
    23
    Initially I thought the low end felt off too; but actually I think it's simply smoothed out the power delivery a bit so there isn't so much of a noticable "kick"
  26. paultownsend
    paultownsend Member
    140
    Squirrel i think you are correct. I also saw a 6g/s from this
    to this
    its just too loud for me. if this wa sa weekend car it would be great. i love hearing the turbo spooling and then dumping. but for my daily, the poor dog doesn't know whats going on! so the cone and reducer for a 70mm maf will be for sale. please PM.
    i like my above airbox. it sounds great but not OTT, and with the PiperX foam filter it pulled a few mg/s more than the OE setup.
    i believe the OE box is a good setup. its just the actual intake hole is too small.
    this way i believe it to be as effective as a foam cone, while giving it some sound and heat insulation.
    Westy likes this.
  27. paultownsend
    paultownsend Member
    140
    I got my Forge tip today. Can't for the life of me see what makes it a second! Only £75!
  28. 16Klappe
    5,795
    1,183
    Maybe I am just a bit young; but nobody has EVER commented on my car being loud.
    I don't get all this smoothed out and less torque nonsense either. :s
  29. ReDBull
    ReDBull Member
    217
    13
    I've fitted one today along with a V2.2 B5 TIP.
    Do people seal around the filter/MAF with silicon?
  30. Tim_Attard
    Tim_Attard Active Member
    473
    44
    Hello just took it all apart ready to fit mine but realised i need a reducer, but would i be better off getting an s3 maf or just getting a reducer so it fits my a3? need the part tomorrow what ever i do otherwise it all has to go back together :(
  31. A3-Lee
    A3-Lee Active Member VCDS Map User
    938
    226
    43
    Just get a reducer mate so much easier
  32. Tim_Attard
    473
    44
    yeah have done a maf was quite a bit so ordered a reducer £15 but meh still doing it ha literally going on 6hrs for catch can and n249 atm damm my broken hand
  33. PiranhaMan
    PiranhaMan Member
    95
  34. Squirrelofdoom
    671
    23
    looks like it to me :)
  35. Tim_Attard
    473
    44
    ive also just realised i have a hose from my air filter box whats is this? and how to i fit it too the s2000? i have an aum a3
  36. WorkInProgress
    253
    Do you mean the hose in the wing? You can leave it as is or remove it for a little more space
  37. Squirrelofdoom
    671
    23
    If you're talking about the small hose with the clip attachment - that's for your SAI (Secondary Air Intake). You can just tie this up somewhere and leave it - or remove the system altogether
  38. Tim_Attard
    473
    44
    No not the cold air feed its a hose that leaves the air box just below the Max and goes down to near the alternator?
  39. Squirrelofdoom
    671
    23
    yes, that would be the SAI like I said...
  40. Tim_Attard
    473
    44
    Ha sorry didnt see ur post, so can I just tie it out the way or do I have to bung it up? Is there any plus to removing it completely?
