Benjamins S2000 air filter mod.
BENJAMIN Apr 29, 2011
  1. jay1
    jay1 Member
    168
    Great cheap mod!!! Did mine today took all of 5 mins and sounds great!! Good find
    :respekt:
  2. s3clarke
    s3clarke Money grabbing s3!
    677
    35
    Does it fit that well that you don't even have to clip it on :D
  3. jay1
    jay1 Member
    168
    Just slides on nice and tight
  4. vrbob
    vrbob Thats no Moon, Thats a space station!
    2,375
    171
    Yeah but it will still move about under load as the tip is not fitted to anything either!
  5. Danny Cawsey
    Danny Cawsey Cawsey
    516
    Mine was so tight it was a struggle to get on, I don't think there is much chance of it coming off although i popped a jubilee clip on anyway :)
  6. danderton
    danderton Member
    84
    +1 to this. Just received mine and pretty happy for the £.
  7. s3clarke
    677
    35
    More than happy with the result! I got the yellow and black filter as well which looks good.
  8. s3clarke
    677
    35
  9. vanilla_ice
    vanilla_ice Active Member
    707
    Result being sound or noticeable performance gains?
  10. s3clarke
    677
    35
    Bit of both in my honest opinion. My car is virtually standard, I put this on and u can hear the turbo which is nice, and it's more responsive.
  11. danderton
    danderton Member
    84
    +1 its quieter than others but there def is bit more flutter noise than others ive used in the past
    defo seems better in response
  12. Sam_
    Sam_ Down under
    3,038
    480
    Surely sound is the same as a regular cone filter due to the design. Filtration is arguably better, with it being paper.
    How did Jardo get on with some proper testing?
  13. gez
    gez S3 hunter
    109
    Im going back to std airbox with foam filter. The noise this s2000 filter makes is horrible. On low revs apply throttle and it sounds like a 1.0 corsa with a cone filter on. Deep throaty and goes nowhere untill boost comes in.
    It is 12"squared larger than the panel filter though and its only £9 so its ok, just not for me.
    im keeping my b5tip std airbox foam filter and 4" ducting the way it was.
  14. IrishDave
    IrishDave Active Member
    682
    45
    Did this today. Only cost me 15euro from my local motor factors. Did not notice any difference not that I was expecting any. Probably just breaths better. Only difference was more noise.
  15. Squirrelofdoom
    Squirrelofdoom Member
    673
    23
    Ordered red/black one for me - arrived today :) But mine too appears to have been oiled....problem?
  16. Squirrelofdoom
    673
    23
  17. IGI
    IGI Member
    85
    Joined the club today just fitted the Blueprint ADH22236 airfilter does come lightly oiled ...blew mine thru with airline just to make sure no excess
    Just heading out for a wee drive:racer:
  18. Lavis89
    Lavis89 Well-Known Member Regional Rep Team Sprint Audi S4 Audi A3
    1,861
    708
    gah still waiting for mine to turn up. going to have to take it into work and blow it through with a air line aswell if it's oiled...
  19. Mk1magic
    Mk1magic Member
    65
    I take it if i want to fit this to a non s3 im gunna need some sort of adapter as ive just brought one of these, stripped down the air box and the lip that attaches to the new filter is alot smaller :S
  20. LSL
    LSL Luke
    71
    Yeah you will need an adapter. I got mine from JSPerformance (thanks for the tip paultownsend) and got the filter off GSF.
    I asked for an 86-70x80mm adapter, I ended up trimming 10mm off the small dia though.
    Fitted it today along with a catch can (zip ties are temporary and many apologies for the dirty bay)
  21. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,186
    No proper testing with the air filters as such, but I can now prove that my airflow calculations were 100% accurate.
    And as such the airflow gains must have equated to power.
    191.2 logged, 239bhp on the RR. 196 logged, 245 on RR. So it was spot on for me.
  22. 16Klappe
    5,795
    1,186
  23. paultownsend
    paultownsend Member
    140
    Looking good there Luke! I haven't actually fitted mine yet. What spec is your car? Do you feel it's made any difference? I assume it sounds pretty mental?
  24. LSL
    LSL Luke
    71
    Almost standard ARY engine (180bhp), I'm having some boost problems so couldn't tell you if it's made any difference. Definitely sounds mean though :laugh:
    edit: better pic
  25. Mk1magic
    Mk1magic Member
    65
    Theres mine, excuse the x2 zipties, they have now been replaced :D
    Sounds fantastic :)
  26. paultownsend
    paultownsend Member
    140
    @Mk1magic
    i never actually ordered my reducer from JSP. What size did you go for in the end?
  27. ReDBull
    ReDBull Member
    217
    13
    Interesting as I need a new filter. Are those of you with out heat shields supporting the MAF in anyway?
  28. Squirrelofdoom
    673
    23
    Cable ties for me until I make myself a heat shield
  29. Mk1magic
    Mk1magic Member
    65
    I had the 70-80mm, was a tight fit but with a bit of fairy and soaking the silicone in boiling water for a couple minutes she slipped on nice ;)
  30. Sam_
    Sam_ Down under
    3,038
    480
    Ah. I was hoping for a proper test on the rollers with a new Jetex vs an S2000 filter. The only real way to fairly test it.
    The paper filtration is good though, just the cost of replacing them at each service will add up. Or buy 10 at once :)
  31. rhubarb4
    rhubarb4 Certified Audi nutter Gold Supporter Team Silver Audi S3 quattro
    1,754
    187
    Would like to see this Sam, just curious to see which filter will come out on top, paper vs performance filter.
    Chris.
  32. S£
    S£ Member
    683
    I never did get round to selling my filter earlier in the thread as there was a problem with paying through PayPal.. So I still have a Red filter for sale here if anyone is after one?
    Was on the car for about 5 mins. Would like £15 + £2 postage
  33. Crazypete00
    Crazypete00 Active Member Audi S3 Audi A4
    495
    61
    I will take it off your hands, pm me your PayPal details
  34. superkarl
    superkarl MAN OF STEEL
    9,496
    2,436
    I sure i speak for everyone when i thank benjamin for this great mod/trend thats caught on. Giving people the gains they want for a fraction of the price.
    Only thing is its a little more difficult to sell our old jetex filters lol
    s3clarke likes this.
  35. S3Zek
    S3Zek Member
    410
    Dose it matter which paper one you get? Gsf? Euro car parts? Ect?
  36. WorkInProgress
    WorkInProgress Member
    253
    Just a quick heads up, these are back in stock at ECP, use code PARTS25 and it comes in at £13.72 with free postage :)
  37. paultownsend
    paultownsend Member
    140
    Just a quick thought on supporting the maf.
    I'm currently using the OE TIP. Next week il be ordering a creations motorsport silicone TIP.
    i take it these are a lot more ridged than the OE item? And with the end of the s2k filter zip tied to the inner wing hook, will provide enough support?
  38. S3Zek
    S3Zek Member
    410
    Is that the yellow and black or red and black?
  39. WorkInProgress
    253
    Will let you know when it arrives this week
  40. 16Klappe
    5,795
    1,186
    Nooooooooooooooooooooooooooooooooooooooooooooooooooo.
    Don't get a Creation tip they are poop, SFS supersized tip or Forge.
