Benjamins S2000 air filter mod.
BENJAMIN Apr 29, 2011
  1. Sam_
    Sam_ Down under
    3,037
    480
    Yeah I wasn't recommending it. Merely showing what was available.
    You'd probably get 2-3 of these filters for the price of one of a decent cone that'll last for ages. Just don't see it myself. Nice experiment though. A huge green cone filter cost me $40. Doubt I'd get an s2000 filter here for $20.
    Those gains you got may well be from the removal of the heat shield. They sit very close to the filter which has to effect flow a bit.
  2. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,184
    My gains weren't from the removal of the heat shield. I had actually removed it before logging to modify it for the S2000 filter.
    With heat shield on or off I always got 191.2, for weeks.
    And as we know, I have most logged A3 in the world haha :p
  3. Sam_
    Sam_ Down under
    3,037
    480
    Ah right, well I've seen others produce more from removing them. Flow vs intake temp.
    191.2 every time? That's very strange to get the exact figure every log isn't it? You'd expect some variance.
    Would be good to test on a dyno.
  4. 16Klappe
    5,795
    1,184
    I have got a pretty constant setup, fmic, coldside kit and oe dv, no boost leaks, always run on only V Power, always logged the full pull in the same place etc. No reason for the peak airflow to change other than with external temps. When it was -2 outside I logged something stupid like 198.
    Dyno results will hopefully follow at the end of the month at Niki's. If the filter can flow well for Phils car then it is good enough for all of you K04 lads too.
    I think Simon Worker (445bhp Leon with a £130 Chinese ebay turbo) has just ordered one too.
  5. Sam_
    Sam_ Down under
    3,037
    480
    Yeah that's what I mean. Temperatures (ambient, heat soak, etc) would effect it. So you make sure you log with everything at the same temperature? Blindly, you're keen.
    I'll probably stick with a cotton one (since I already have it) but I did look at the 42dd velocity inlet. It's a nice bit of kit but pricey. Didn't think a velocity stack would make much difference though. It didn't when Bill tested it on his Lupo I think? I guess we'll see when you get it dynoed.
  6. badger5
    9,429
    1,974
    Remembering the MAF is a MASS AIR FLOW meter, so colder denser air is colder and denser.. and the hot film MAF knows... (more cooling effect across its hot film element) - maybe same velocity passing by, but more Mass..
    Seeing the dyno results will be the main thing..
    I have tested Many Many filters and seen much wider variance on g/s from MAF, but in power measurement differences? meh..... in the realms of measurement scatter difference wise..
  7. Sam_
    Sam_ Down under
    3,037
    480
    Bill, you didn't see many gains with a velocity stack right? Any use on an ickle GT28?
  8. badger5
    9,429
    1,974
    I tested filters inc one with velocity stack 6" filter neck, 76mm MAF size..
    It read the lowest g/s combined with the K&N filter, BUT, made the highest power... Removed filter and zero difference in logged g/s
    I think it presented the cleanest non-turbulent airflow to the MAF as my best guess as to what was occuring.
    When I say made highest power, its was very very small variances between the filters, and the max/min were in the realms of measurment scatter from engine temps between the runs.. Very inconclusive in power terms.. In logged airflow terms you could be conned into thinking otherwise however.. which is why airflow overall, taken as the Only measurement of gains, is flawed.
    I like the idea of radius stack and have used these on our BT cars which use the RS4 MAF housings, and we make a billet radius stack to hose the MAF and clamp the filter onto.
    and installed in the GT3076 TT
    fanta likes this.
  9. Prawn
    11,456
    3,353
    I really don't know why Hollie had forge remake that charge pipe Bill. The one you made looked SO much better!
  10. Prawn
    11,456
    3,353
    vanilla_ice and ChrisShepB7 like this.
  11. BENJAMIN
    BENJAMIN Active Member
    503
    93
  12. Prawn
    11,456
    3,353
    Oh really? If that's the case I may go and buy one this week just to test it :) Any chance we could do a run with /' without when I pop down to play with cams? We need to sort that out at some point, and that fuel pump, and I want to see this M3 :D
  13. BENJAMIN
    503
    93
    Yes, yes and yes.
    Think we need a little drag race to 155! Lol
  14. Prawn
    11,456
    3,353
    Awesome :racer:
    What about first to reach 160 :laugh:
  15. badger5
    9,429
    1,974
    because.. lol
    mine was easier and more practical to remove for access of things.... the one they had made is near impossible to remove as its join is behind the headlamp.. {sighs}
  16. s3gazz
    s3gazz Well-Known Member
    1,376
    99
    all sounds really good but getting car mapped first lol been waiting years
  17. Rich196
    Rich196 Member
    105
    People have been using this filter on the TT forum for nearly a year nowm always get good result, good value for money!
  18. turnstyle
    turnstyle Member
    91
    Brand snobbery?
    Ive just ordered one of these filters from the local eurocarparts. Air filter needs replacing anyway... and for the sake of £18 why not.
  19. Lavis89
    Lavis89 Well-Known Member Regional Rep Team Sprint Audi S4 Audi A3
    1,822
    666
    This thread made me very happy. just ordered one seeing as im binning my K&N filter and buying a new MAF before getting some diagnostics done. finally going to get back into working on mine TQS, need to get the engine running spotlessly then i can get the paint fixed!
  20. Westy
    Westy Well-Known Member
    17,443
    1,103
    This thread will raise the price of the S2000 filter just like with the LCR front splitter!
    Ian Betton likes this.
  21. Sam_
    Sam_ Down under
    3,037
    480
    Cheaper re-usable filters for the rest of us then? ;)
  22. 16Klappe
    5,795
    1,184
    You can still get an LCR splitter for £36 direct from Seat, it is just that nobody bothers and buys them straight off ebay for £45.
  23. *P3nfold*
    *P3nfold* Member
    368
    15
    Is this thread worth making it sticky? Sounds like a bargin.
  24. Westy
    17,443
    1,103
    Once apon a time they were even cheaper then this.
    My Jetex needs a bloody good clean. I might just get one of these S2K ones.
  25. jojo
    28,856
    3,516
    No. :laugh:
  26. Jason.s
    Jason.s Active Member
    2,879
    348
    Mmm nice I can get one from euros for 9.95 plus vat lol.
  27. BENJAMIN
    503
    93
    ERF's car in for a catch can and s2000 filter. He joined the filter club!
  28. badger5
    9,429
    1,974
    just needs a nice high flow tip now :)
  29. Erf
    Erf Member
    243
    I was just about to upload that picture! Ben you are a legend! Cheers for sorting out the oil catch can and filter for me. The car felt great on the way back home! Well worth the trip out to see you guys. :icon_thumright:
    Bill, will sort out a TIP as soon as I can get my 4wd working...:banghead:
  30. Erf
    Erf Member
    243
    Also - I think I left battery cover at the garage. Can you put it to one side until I see you guys in the next couple of weeks?
    Cheers!
  31. harvey01
    harvey01 Member
    523
    9
    ive just got my self a mugen performance s2000 filter lovley
  32. dancuz
    dancuz Member
    140
    Also joined the S2K club today - Cheers Bill!
  33. Sam_
    Sam_ Down under
    3,037
    480
    Aren't they foam?
  34. BENJAMIN
    503
    93
    It's in the boot, along with your airbox mate. :)
  35. Dani_B19
    9,168
    363
    Can these be ordered off eurocarparts website? Carnt find them anywhere Nd its a right mission to the nearest eurocarparts depot.
  36. harvey01
    harvey01 Member
    523
    9
    got mine from gfs £18.08 posted but then found a mugen one and got that to
  37. schwartza3
    schwartza3 Member
    81
    52
    I had a large cone type filter on the car for a few years, got sick of noises/whistles and swapped back to the box with cold air feed and enlarged opening. Didn't realise how much low end torque was lost with basically no top end gain. Has anyone else had the same experience?
  38. Westy
    17,443
    1,103
    I did back to back dynos at Bill's and we found the Jetex cone gave nearly 10bhp and 7lbft (I think, my memory is rubbish so it might have been more) of torque at peak over a smoothed airbox.
  39. vanilla_ice
    vanilla_ice Member
    698
    22
    Was that with a 3" TIP fitted too?
    Are cone filters that much noisier than an aftermarket panel filter and airbox?
  40. Westy
    17,443
    1,103
    Yes mate. 3" B5 TIP was on the whole time for both tests.
