Belt Noise From Engine?
leeds2592 Mar 27, 2013
  1. leeds2592
    leeds2592 When I grow up, I want a 964!
    1,399
    222
    Hi all,
    My A3 (info in sig) has started to make a noise from within the engine bay. It's quite hard to describe but it's a squeeking sort of noise that sounds like a belt and kinda like a turbo, although mine isn't a TFSI. The pitch of the noise increases as the revs get higher.
    It's currently on 72,000 miles and is 6 years old so I know the cam belt and water pump need to be changed (getting done after next pay day). Could it be this that's making the noise? I don't want it snapping as I know I'll be pretty much buggered if it does.
    I know it's pretty difficult to diagnose without hearing it in person, but any help would be appreciated.
  2. NHN
    29,417
    1,740
    Put a 17mm spanner end on the aux belt tensioner raised arm piece & move it so the belt seems a bit tighter, see if the noise goes, then if it makes a difference remove the belt altogether & see when running without if noise goes, if so then its either a belt, tensioner or pulley.
