Been Offered a swap
Nutkin Oct 25, 2010
  1. Nutkin
    Nutkin Member
    830
    My A4 1.8T Quattro S Line Avant for a A3 3.2 Quattro 2004.
    Just wondering what the problems and niggles with the A3 are.
    My A4 is on 76k miles and the A3 is on 28k so mint tbh.
    Whats the deal with aftermarket bumpers and stuff too dunno whats popular to make it a bit mroe modern looking as its not an s line.
  2. sub39h
    sub39h Active Member
    2,502
    you can do a first facelift upgrade relatively easily. if you're sticking with Sport > Sport all you'll need is a bumper, bonnet and rad grill.
    personally i'd go for the S-Line front (for which you'll also need the fogs and fog surrounds), and then the '09 S-Line rear.
    the 3.2 had some problems with hesitation, which required a reflash of the ECU to control. others are having problems with timing chains, which is a £10k repair. if you do a search there's pages and pages on both.
    i've test driven the 3.2. it's a lovely motor, but the 2.0T gave me almost all the thrills without any of the drawbacks of reliability or fuel costs etc. if the 3.2 was more reliable and i had a bit more spare cash i'd have definitely gone for one
  3. Sarah's A3
    Sarah's A3 MODERATOR V6 S3 Hybrid Staff Member Moderator
    5,920
    30
    Well the 3.2 will make you smile. Yes some have had the hesitation issue, mine did, but a simple ecu flash sorts it out straight away. Easy to test if it has it, put the car in neutral and see if it will hold 2k revs without the needle darting around.
    Chains, well not many have had to have these done. Its not 10k to do even at Audi, more like 4K. They can be checked using VCDS to see if they have stretched. Mine were showing possible change needed but did an oil change and re tested anf they are ok. The engine seems to get a lot of rubbish in there so doing extra oil changes does help.
    All in all I love my 3.2 as most on here will tell you. Ok so there are a few issues but so does the 2.0 tdi engine. The only draw back is the fact it cant really be mapped but tbh Im happy with the power output so not an issue for me.
    Changing the bumpers is an easy job, I did both of mine and really happy with the results.
    TBH, with the mileage on the one you aer offered, it shouldnt really be an issue.
    Good luck choosing
  4. sub39h
    2,502
    swear paddy said £10k? thanks for clearing that up tho...
  5. Sarah's A3
    5,920
    30
    Paddys 10K was for a load of work not just the chains
  6. sub39h
    2,502
    ah that makes sense. cheers :thumbsup:
  7. Smoothie
    Smoothie Active Member
    1,431
    Off topic but lucky they didn't write the car off if it needed 10k
  8. Sarah's A3
    5,920
    30
    the 10k wasnt for the repairs after the accident, it was all done before that. Paddy had a misfire issue and Audi were investigating it, they just couldnt find the cause.
  9. Smoothie
    1,431
    Makes sense cheers
  10. Sarah's A3
    5,920
    30
    No probs. Sure he will be along to explain better.
  11. paddy
    paddy Audi=No fault code, no idea
    5,152
    133
    My chains were £10k because it took Audi 3 weeks to diagnose the problem so they were talking nearly £5k before they started the fix ! to do the job properly you could be looking at another £5k because while the chain is cheap you really need to change tensioners and sprockets. the back tensioner is part of the timing cover and that is £500 alone. mine needed cam position sensors and solinoids as well etc. It would be cheaper if you take it to an independent but bear in mind its a gearbox out job which is not easy on a DSG. I was lucky that audi picked up half the bill but you cant count on that. first signs of trouble are a mis fire after starting for a short time and a fault code and engine light for Cam position set point not reached. V6Pete had the same issue and i think his bill ran to about £4.5km. The trouble is that at £150 an hour thats £1k a day so just looking for the fault can run you into a lot of money before they even start a fix....as i found out :)
  12. edition
    edition Active Member
    1,426
    Yeah a thumbs up from me on then 3.2 :)
  13. beanoir
    beanoir Large Member
    2,171
    30
    Hold on a minute, you have a 2009 A4 and thinking of swapping for an A3 5 years older?! Personally I would keep the A4, it's a much nicer car, more refined and Avants rock!
  14. crazy88
    crazy88 Loving the anonymity
    4,939
    437
    No...as far as I know he got his A4 in 2009. It's a b6, so gonna be 2002-2004ish i reckon.
  15. beanoir
    2,171
    30
    Oh I see! Still wouldn't swap it for a 3.2 A3 to be honest. I loved my Avant and they feel much more solid cars than the A3.
  16. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,483
    Are you planning on modding the 3.2 V6 or leaving it as is?
    Turbo cars are far cheaper to see gains from performance wise if you ever wish to go down the line of more power. I assume the change down from the A4 to A3 means you won't be looking to be growing your family any time soon, so are you hoping the A3 will be a more focussed drive?
    As you just hoping to shift the A4 because of it's mileage?
    3.2 is going to sound sweet as, but I'd test drive one before you make your mind up as they deliver their power in a very different way. I drove a 4.2 V8 S4 (2007) the other day, and whilst it is every bit as quick as my car it felt slightly lazy (all illusion).
    Tough call, but I'm a great believer that if it makes you happy when your behind the wheel then your onto a winner, so only you can decide. Best of luck.
  17. smudge_don
    smudge_don Active Member
    2,944
    He bought it in 2009 Nick, pretty sure it's an 02 plate when i last saw it
    Nutbag, from what i've seen on here the 3.2 has a few design flaws which leads to some problems, but it's like any car. You either get a good one and are very lucky or you get a right dog from the start
    I'd keep with the A4 Avant in all honesty
  18. col6821
    col6821 Member
    177
    3.2 (or larger) all day long :)
    I've had an 8L S3, a Mk1 TTR 3.2 manual and now a 2004 A3 Sportback 3.2 DSG Sport, it's probably the best of the bunch...
    Col
  19. Nutkin
    Nutkin Member
    830
    Its an 04 so same year. TBH my turbo causes all end of problems so i was hoping a switch to a v6 would get rid of boost hoses and the like giving me head aches
    From what I've read though i'd be better off with the A4, its just the milage is working its way up, although now I hardly do any miles as I drive company cars most the time, just cause they are more fun tbh.
    Drove to oxford today from birmingham and got out very relaxed and fresh as if id just driven to the shops. Jag XJ btw.
    So not fussed about mpg anymore which was why i ended up with the 1.8T Avant as it offers performance and 36mpg when needed.
  20. Sarah's A3
    5,920
    30
  21. CraigHarrison
    CraigHarrison Member
    118
    I think I would kill myself if I didn't have boost in my life...
  22. edition
    1,426
    Some people prefere turbo'd cars some prefere bigger c.c. ( I prefere C.C.).
    I would say the 3.2 is a lovely car and just about right performance wise for the roads. I like the relaxed way you can get from A-B and the feel that you are driving something grunty that you dont get with a turbo's car.
  23. N8
    17,163
    718
    A3 is a lovely car when modded right :happy:
  24. beanoir
    2,171
    30
    You wont get as much 4x2 in the back as you would in the Avant ;)
    I do wish people wouldn't make out the 3.2 is some kind of monster engine, it's just a pony little excuse for a V6 to be honest, I've had them in the past and they don't have any more "grunt" than a 2.0l with a turbo, they just have a smoother power delivery thats all.
    Everybody knows the 3.2 was a poor man's S3 ;) (ooohhh see what I did there!)
  25. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    :laugh::laugh::laugh:
  26. Nutkin
    Nutkin Member
    830
    Id say it was an impatient mans S3 as it was out for a few years before hand.
    Im gonna go have a drive of it and see what I think.
  27. sub39h
    2,502
    i don't think that's entirely fair. they're different beasts.
  28. paddy
    5,152
    133
    Nearly right....Everybody knows the 3.2 was a man's S3
  29. paddy
    5,152
    133
    Now look here Beany old chap....for someone who seems proud to have owned an XR2 your getting way out your depth :) :)
    Most people who buy a S3 need to chip it within days they feel so let down !! Most people who buy a 3.2 are happy with what the bought :) this pony little V6 produces the same power as a turbo'd 2ltr ! without the hassle, it gives a smoother power " Without" turbo lag, sounds a lot better and doesn’t eat clutches....People with 3.2's are decidedly better looking and generally more intelligent and go on to become destined for greater things….S3 owners can look forward to a life of misery and vandalising bus shelters.. the S3 is the devils work and if it was too wet for God to take his Ducati to work he would use his 3.2…..just like me..See what I did there ;)
    Now….run along J
  30. paddy
    5,152
    133
    AND................how can it be a poor mans S3....mine has cost £4000 a year on Average just to keep it running over the last 3 years :) beat that !!
  31. beanoir
    2,171
    30
    Brilliant, I know I cast the bait, but I didn't expect 3 fish on one hook! ;)
    Right, I'm off to batter some grannies.
  32. paddy
    5,152
    133
    Get one for me :)
  33. Nutkin
    Nutkin Member
    830
    Ermm you are meant to be talking me into this!!!
  34. smudge_don
    2,944
    Paddy's case is just unreal, might as well have scrapped it and bought a new one. Would've been less
    Join the club Nutbag, but you'll only be as good as i was....and even worse, you'll only be as good as Navajo!!!!
  35. edition
    1,426
    hahaha I think that's right Paddy, just ask Sarah.
  36. smudge_don
    2,944
    :lmfao:
  37. Sarah's A3
    5,920
    30
    haa haa on yeah! I prefer a mans car as alot of you know, no flimsy girly pretty s l o w cars for me! or were you hinting im a guy lol!
    Beanoir, mind those grannies dont beat ya back lol! Although they are probably driving around in an S3 haa haa!!!! See the 3.2s just too much and manly for them ...............lol..... (i'll get my coat!)
  38. beanoir
    2,171
    30
    More likely the granny, watch out for S3s!! haha ;)
  39. Sarah's A3
    5,920
    30
    Oh yeah I forgot, grannies will need to watch out for those S3s, they wont be able to afford all those clutch and turbo issue costs on their pensions! Well pointed out Beanoir! lol......... (come 'er little fishy!)
  40. beanoir
    2,171
    30
    Perhaps they could use their bus passes and hitch a ride in your 3.2!
