Bearing noise when setting off in first gear is it my turbo?
Dj Vegas Nov 15, 2011
  1. Dj Vegas
    Dj Vegas Member
    73
    when i first start my car in the morning i set off in first gear and it sounds to me like my turbo bearings is on its way out
    any body had a similar problem with turbos?
  2. Westy
    Westy Well-Known Member
    17,443
    1,104
    Can you replicate the noise in any other gear? does it only do it when the car is cold/warming up?
  3. Dj Vegas
    Dj Vegas Member
    73
    only first thing in the morning then fine does it a little in second gear
  4. Dj Vegas
    Dj Vegas Member
    73
    yes cold / warming up
  5. Westy
    17,443
    1,104
    Could well be the turbo then just before the oil warms up around the bearing. Do you know if it's the original turbo and how many miles it's done?
  6. Dj Vegas
    Dj Vegas Member
    73
    i would think so but not really sure im having a bit of bad luck atm haha its done 140'000 thousand miles so quite a few but drives like a dream to say its done that many i have installed the ebay FMIC do think that the N75 valve could be to small?
  7. Westy
    17,443
    1,104
    If you have full service history and cant find anything to say the turbo has ever been changed then it's had a good life! Unless you start to get blue smoke out the exhaust or this noise gets really bad I wouldn't worry too much.
  8. camscockle20vT
    camscockle20vT The stigs ugly brother
    1,740
    77
    I agree with westy, but to add to your dilema i would ask, do you wait atleast 30 seconds before turning your engine off?
  9. Dj Vegas
    Dj Vegas Member
    73
    yes i leave engine running foe 30 secs cheers westy
  10. Lee172
    Lee172 GT3071
    430
    I dont understand why the problem would be the turbo if its in first gear only. Do you let your car idle for a minute in the morning or drive stright away?
  11. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Are you sure its not the secondary air pump you can hear?
  12. a3tdi2001
    a3tdi2001 Member
    437
    Have you considered your gearbox? Does it make the noise when stationary? Could be worth a change of gearbox oil?
  13. Mike B
    Mike B Well-Known Member
    1,101
    40
    Agree if its the turbo it would do it if you revved in neutral if not g/box oil may be low or nedd changing
  14. <tuffty/>
    21,386
    3,940
    Define this noise... K0x turbos have a journal bearing so I am not sure if they would make a 'noise' and if the bearing was that worn it would be noticable in performance terms...
    Ball bearing turbo's like Garrett GT's do make a rather nasty noise when they are about to let go having experienced one do exactly that on the dyno once...
    You can check for wear by taking off the TIP and trying for play in the shaft... if you can pull it in and out a lot then thats thrust bearing wear... excessive up and down play will be the journal bearing...
  15. scott6452
    scott6452 New Member
    15
    I currently have the exact problem described. Just a tinny rattle when the engine is picking up from low revs when cold. As soon as the car heats up the noise is gone. Not sure if it is just a coincidence but my s3 has just turned 130000 miles also with original turbo. No other turbo problems however, apart from a mega boost leak that im sure isnt doing it's life much good.
    Im sure i'd love the car a whole lot more if i could find the source of this bloody noise and get rid of it!
  16. Inertiauk
    Inertiauk Active Member
    574
    29
    Mine got a bit noisy like this just before the turbo seals went, its not as noticeable in higher gears because its overpowered by other noises.
  17. aragorn
    18,444
    848
    The noise of a K03 failing is usually described as being like a dentist drill.
    I've noticed my turbo makes a sort of wooooooooo noise predominantly when cold when driving at low load, ie pulling away. I guess you could describe it as "ghosty" noise.
  18. Dj Vegas
    Dj Vegas Member
    73
    where would you find the secondary air pump?
  19. <tuffty/>
    21,386
    3,940
