BBT hybrid with New Badger5 high flow k04 exhaust manifold first tests look promising
badger5 Jan 4, 2014
  1. badger5
    9,633
    2,071
    K03 hybrid on Lupo compared to the BBT K04 hybrid on my new test K04 high flow exhaust manifold...
    Looks promising power/temp wise.
    EGTs max on the plotted run 825'c measuring in normal k04-023 position factory stylee.
    I need a stiffer actuator.. This run was on 9psi actuator cranked to give 10psi actuator only boost.. Swapped to a forge one I had on shelf with white spring, and it ran less boost.. doh! 15psi BBT actuator to get asap and then continue with this and find the actual limit as I am not sure I'm there yet. EGTs being my guide, there's some left in it if I can hold more boost up top.
    Very pleased with the result so far.
    More mods to come to see what we get.
    Manifold works fine :)
  2. Brodster
    Brodster Well-Known Member TeamMisano Team V8 Audi RS4 Audi Avant Owner Group s tronic
    3,554
    896
    OOooOO.........Matts gonna be happy as hes waiting for this mani to complete his S3 build. Running on stock mani just now but waiting for your manifold Bill..............any ideas of timescales????
    hoffmanvp3 likes this.
  3. daz-20vt
    daz-20vt Well-Known Member
    2,836
    584
    Ohh very interesting. Not having a desent reliable mannifold on the market is so annoying. Especially when you cant diy. I couldnt afford to do this job twice. Any idea on prices etc? How easy are they to fit? Any info would be awesome
  4. Gops
    3,198
    666
    I can vouch this manifold is great, I have it on my car! Adds more growl if anyone is interested in sound! Good work bill! Seems so tempting as its only a turbo swap away from me!! Haha!
  5. badger5
    9,633
    2,071
    I am testing the upsize bore version which should have a badger5 modified hotside to suit. Gops has run the std sized version on baby hybrid to 315bhp fine.
    jitvv and Gops like this.
  6. <tuffty/>
    21,960
    4,229
    I painted the cam cover :D
    Sam_, badger5 and Gops like this.
  7. daz-20vt
    2,836
    584
    Gops do you have a build thread?
  8. chaz20vt
    chaz20vt Member
    428
    21
    Excellent results so far ............
  9. superkarl
    superkarl MAN OF STEEL
    9,623
    2,488
    That's an awesome result
    Which hybrid?
    I notice the vid is titled k16/2283, but I though the big daddy bbt was tfsi turbine now?
  10. badger5
    9,633
    2,071
    The spec was my choice which Dan kindly made for me. The hotside I have significantly reworked to assist flow, which seems to be helping keep Egts relatively cook for the power output from this framesize turbo.
  11. chaz20vt
    chaz20vt Member
    428
    21
    Any ideas when this manifold will be complete for sale
  12. daz-20vt
    2,836
    584
    And how much change we get from a one'er ?
  13. badger5
    9,633
    2,071
    292.67+vat is manifold price which will include stainless steel turbo bolts, nordlocks, and gaskets where applicable.
    panderoo, *P3nfold*, kwistof and 2 others like this.
  14. chaz20vt
    chaz20vt Member
    428
    21
    When will they be available bill?Also hows fitment compared to "other" manifolds? Not a head of job I take it
  15. Prawn
    11,712
    3,725
    Having seen these manifolds today, they look fantastic!
    Fitment will be very easy too from what I saw when compared to other nasty fitting aftermarket things!
  16. Gops
    3,198
    666
    Better made, won't crack like others, ports align, better fitting - just to name a few. It feels so much better made than others I've seen! Larger port ftw
    AVLO and russwuss like this.
  17. AVLO
    AVLO Active Member
    295
    52
    There is obviously going to be a big market for this manifold bill as reliability and fitment are what matters as well as flow. Just one question are they all going to be large port or will it be an optional extra??
  18. badger5
    9,633
    2,071
    largeport version might be a little dearer but not much if at all, but it will require a hotside to match it.. The Genuine BW hotsides might have an issue with their inserts if they protrude at all, as the bore is close to the mounting holes for the bolts. Largebore is run gasket less also, so new "flat and smooth" flange face is required to ensure a seal.
    The std size bore version is +1mm over stock but the maximum a factory gasket is which sets the max size. Turbo hotside obviously as std and normal hybrid are the same bore entry size.
    Gops likes this.
  19. antwan64og
    antwan64og Active Member
    854
    219
    43
    Bill, if I'm reading the data right and you set max boost to 20psi it would reach it @ 4500rpm and could hold it till redline.
    It produces 240hp at 4500rpm but have you any idea what the peak would be @ 20psi
  20. badger5
    9,633
    2,071
    15psi actuator now sourced and fitted and on dyno again now..........
    updates will be on our facebook page
    https://www.facebook.com/Badger5Ltd
    I want to see what the trade off with boost, flow, egts is vs power/torque... Testing continues.
  21. russwuss
    russwuss Active Member
    549
    106
    43
    Very interested to see the difference the 15 psi actuator makes... may invest in one of these myself :)
  22. Jersey
    Jersey Member
    116
    14
    Hi guys,
    Just a quick question, please don't slate my lack of knowledge!
    Would this new Badger5 manifold be beneficial to a stage 1 revo mapped car? Or would it need to be custom mapped?
    Cheers,
    Jordan
  23. antwan64og
    854
    219
    43
    if you get a chance pretty please do one run at 18 or 20 psi, interested to see how smooth the power is at what i'd run on the street
  24. badger5
    9,633
    2,071
    when you change hardware mods, I would always suggest custom map to make benefit from improved hardware.
    It would help, but I would not expect by much.
    I would be putting my ££ on other mods first to improve flow, cooling etc... intake, downpipe, fmic... then the slippery slope takes hold :)
    Westy likes this.
  25. badger5
    9,633
    2,071
    and it continues..........
    s3dave likes this.
  26. Prawn
    11,712
    3,725
    ******* :sign_unfair:
    That's my bonfire well and truly pissed on them :lol:
    I think gear based boost will be required for this one!
  27. s3tt
    s3tt New Member
    Just build it it bigger then...
  28. Pedrosousa
    Pedrosousa Member
    175
    It's time for the hybrid version of yours...
  29. badger5
    9,633
    2,071
    firmly off for MrsB.. 288bhp/235lbft(273lbft) badger torques for her daily.
    Its max has been reached from this hardware..
    Smallport head. Stock AUM motor and we're pushing it hard and its pushing back now.. Edge reached.
    A little more left in the turbo, but we need to encourage the engine to use it - lol
    Plans for this ready, but they will wait a while, whilst MrsB enjoys her car back after many many months of me buggering about with it.. and it sat patiently in the "to do" queue
    Its reached/suppased my expectations without the additional mod planned.. so we shall see what that does in due course..
    manifolds working well. egt's nice 845-855 max on the 23psi level
    I do wonder what a largeport head would allow it to do, but thats just a 'thought' I will park for now.
    Tired now.. as is poor ickle lupo I bet. poor thing.
  30. Prawn
    11,712
    3,725
    I already did :laugh: but I was hoping my 353bhp record would stand for a little longer, it lasted 13 months before being beaten by Bill :)
  31. Gops
    3,198
    666
    Epic results these are! I was hoping it would be record breaking! I wanna upgrade my turbo now ;)
  32. hoffmanvp3
    hoffmanvp3 Active Member
    304
    81
    Just waiting on a fresh batch of hot sides with egt to come in for Dan to swap out with my exsisting BBT KO4 hybrid Which Will Be Getting The B5 mani.
    Bill, Dan said you'd be doing the large port mod on my mani and Dan would send over my Hybrid hot side to match up:)
  33. badger5
    9,633
    2,071
    do you know of any others who were your figure prawny? Were they large or smallport jobbies?
  34. badger5
    9,633
    2,071
    fine.. I need to figure out time/costs for this bit.
  35. hoffmanvp3
    304
    81
    Kool bill, might be a while until those pesky hot sides turn up. If they take to long I'll just weld on the bung for the egt probe and send that hot side to you but will let you know before hand.
  36. superkarl
    9,623
    2,488
    you're forgetting gazz
  37. Prawn
    11,712
    3,725
    Nope, I'm not. 352 is less than 353 where I did maths!
  38. Prawn
    11,712
    3,725
    Niki had one make 352 on large port with an SEM also, but dialled it back to 335 before leaving, Gaz saw 352 also on a dyno somewhere up north, on a worked large port.
    Mylos once saw 348 on the ko3 frame thing at Nikis, but from a monster boost push and low down, realistic was closer to 300-310 long term.
    Not aware of many others getting much over 330 though anywhere.
  39. superkarl
    9,623
    2,488
    Deeply truly sorry prawn. I thought it was more
  40. *P3nfold*
    *P3nfold* Member
    368
    15
    Sounds awesome at last a manifold built to last compared to the relentless.
