BBS Speedlines Refurbing :|
Farhan May 21, 2011
  1. Farhan
    Farhan Active Member
    1,234
    57
    Right all i just bought some speedlines and i needed advise!
    The speed lines have surface corrosion on the outer lip only and i wanted to just have them repaired to oem standards.
    The centres are in great condition its just the outers which need attention. Can anyone recommend who to get these repaired from or if its possibly to spray the outers to an oem color instead of splitting them all.
  2. N8
    17,163
    718
    I would do them, but I'm in manc your in london, so get lepsons in Gillingham to do them.
  3. Lings
    Lings Active Member
    2,059
    31
    Are they kerbed bad?
  4. Farhan
    1,234
    57
    daymn! ill give them a shout if needed nate
    Steve - From what i can tell from the photos they have mainly scuffs on the outers but no major curb marks. The scuffs have caused a bit of corrosion onto the lips but luckily the centres and bolts are all in very good condition.
    I dont mind giving them a go myself and getting my body shop to spray them up. I would prefer them to stay in one piece ideally but if splitting them is the only option i would rather take it to someone who knows what they are doing
  5. flying oyster
    flying oyster flying oyster
    563
    27
    I've split mine today and started to refurb them i've not had a problem so far
    Mine were badly curbed but they have come up a treat i vapour blasted the centres
    ready to prime and paint have a go just take it easy getting the bolts out
  6. N8
    17,163
    718
    Yeah you need to split them to do it properly.
    tonydata likes this.
  7. Lings
    Lings Active Member
    2,059
    31
  8. flying oyster
    563
    27
    Im still not sure to go satin black centres and gloss lips or all satin black
  9. Lings
    Lings Active Member
    2,059
    31
    what colours your car?
  10. flying oyster
    563
    27
    Akoya silver
  11. N8
    17,163
    718
    All satin black splits:
    Mujnu and tonydata like this.
  12. Lings
    Lings Active Member
    2,059
    31
    Would defo have a polished lip myself
  13. flying oyster
    563
    27
    I think satin as well :wub:
  14. Ash187
    7,478
    735
    Hey Farhaan,
    try these guys, not too far from you either mate.
    First Aid Wheels
    www.fawheels.co.uk
    02074350941
    07966170469
  15. Farhan
    1,234
    57
    Looks like im going to have to split them! 8mm spline right? Are the bolts solid? I always have bad luck rounding stuff off LOL
    Going to get a compressor and split these, get the outsides sprayed!
  16. N8
    17,163
    718
    M8 spline yep.
  17. FranA3
    FranA3 events moderator Regional Rep Gold Supporter Audi A3 Team Brill Red
    7,228
    320
    i do like those black speedlines n8 very :wub:
  18. yuan2211
    yuan2211 Member
    147
    i think the outers polished may be better but trying to split them my be a c**t mine are given up for the moment till i can be bothered again pus the bolts keep rounding off so now need to spend another 130 on them a right :asskicking:
  19. Lings
    Lings Active Member
    2,059
    31
    The original bbs bolts normaly come out fine .The cheap replacements are the problem .they are not proper titanium they snap ,the splines fall to bits etc etc .If the bolts are branded just usea longer handled rachet/torque wrench to remove them, take it slow and do not use power tools that will just strip them faster.work one bolt then go to the other side of the wheel .Its time consuming .But worth it .Out of 2 sets of my splits ,only one bbsvs bolt snapped.19 of the cheap ones broke ...Try to find stamped replacements if you break any..
  20. James.Asbri
    James.Asbri Vorsprung Durch Technik
    1,176
    If I had the cash, these would be on mine!
  21. FranA3
    7,228
    320
    same here mate
  22. N8
    17,163
    718
    Those ones have sold now, went to a lad in Ireland, but I have 2 more sets, 1 8.5 all round and another staggered, so get your orders in :laugh:
  23. Farhan
    1,234
    57
    Guys the splitting has begun! Removed bolts off two wheels, going to do the other two tonight. All going smoothly so far touch wood.
    Just one question does anyone have any idea what torque specs the bolts need to go back in. I was thinking 20lbft with thread lock
  24. evocos
    evocos Member
    512
    9
    I had the outers polished and centres done in range rover rimini red,on my 4x4 :laugh:
    Obnoxious Kids likes this.
  25. Farhan
    1,234
    57
    seens yours at UD bro looked excellent.
    Now decisions polished....or diamond cut lips hmm
  26. evocos
    evocos Member
    512
    9
    Thanks mate,yeah its getting there.
    I think polished look very slightly better,BUT are a pain in the butt to keep clean.
    Diamond cut is the more sensible option and still look amazing
  27. Farhan
    1,234
    57
    Yer polished worries me for that very reason. Im good with keeping my wheels tidy and clean but the way our winters have been lately i dont intend on keeping my standard s line wheels so diamond cut it will have to be :-(
  28. Lings
    Lings Active Member
    2,059
    31
    From the polisher on E38 22ft/lds torque, no sealant, loctite on the stud threads.This is what i did, but beware these are alloy over tighten and the threads will simply give they are pretty soft matey .:thumbsup:
    Mine are polished and covered in Renaissance wax ;)
  29. Farhan
    1,234
    57
    good stuff bro, ew aluminium......i remember stripped threads on my last rocker cover NIGHTMARE! i also have extremely bad luck with rounded, corroded, seized nuts and bolts.......seriously and i out of all people follow strict procedures. Wish me luck ill be needing it :salute:
  30. Lings
    Lings Active Member
    2,059
    31
    Your be sound LOL
  31. N8
    17,163
    718
    Jules is right about Polished/Diamond Cut, spot on J :wub:
  32. ShaunS3
    ShaunS3 Yorkshire & Humber Rep. Regional Rep VCDS Map User
    1,172
    214
    Anyone know what the standard silver is that Audi use on these rims?
  33. Lpool88a4
    Lpool88a4 New Member
    I have just bought some 19" bbs speedlines and woyld like to know the exact size/spec of the bolts that hold the wheel together?
  34. gateseb7
    gateseb7 New Member
    What is the correct torque for reassembly? Mine are currently stripped in for refurb.
  35. Adam Russell
    Adam Russell Member quattro Audi A4 S-line owners group TDi
    186
    might sound a silly question but can i split the rims with tyres on? or do i need to remove the tyres ?
  36. Orange225
    Orange225 Active Member
    967
    128
    43
    Yes you can. Personally I'd let the air out though
