Battery securing
madmike01uk Mar 13, 2013
  1. madmike01uk
    madmike01uk Member
    430
    21
    My battery isn't secured properly, what should be securing my battery to the car? Anybody know what the part number is? I need to get this sorted.
    mike
  2. quattrojames
    14,050
    574
    It's a bolt with a bracket, part numbers here:
  3. quattrojames
    14,050
    574
    3 - 8E2 805 229 A
    Beyond that, you need to take your battery out and see whats missing, it's probably just the bolt.
  4. madmike01uk
    madmike01uk Member
    430
    21
    Cheers, I will take it out tomorrow and see whats what.
  5. benjie
    benjie Well-Known Member
    1,223
    304
    If nothing is missing, you need to loosen the bolt, then straighten it up, so it looks like it's standing up/leaning back. You can tighten it up and if it's at the wrong angle/position by 2-3mm, it will not secure the battery.
  6. Andie0
    Andie0 Member
    490
    13
    Had same problem, some non oem batterys are incorrectly sized and simply will not tighten down without a spacer between the clamp and lip on battery i used a 3mm long allen key and slid it between clamp and lip then clamped that down on to battery to get the extra i needed so clamp would engage! Doesnt move at all anymore!
