Battery relocation
StaceyS3 Feb 4, 2013
  1. StaceyS3
    StaceyS3 Well-Known Member
    2,505
    502
    Sorry I know I posted this in my thread but have also posted (copy and pasted) this here to try and catch some more peoples ideas ;)
  2. <tuffty/>
    21,251
    3,879
  3. StaceyS3
    2,505
    502
    Yeah did have a read through yours when was googling ;)
    Where abouts did you get your terminal blocks from?
  4. <tuffty/>
    21,251
    3,879
  5. StaceyS3
    2,505
    502
    Lovely cheers mate, had tried searching but must have not been searching under the correct termination lol
    You got any ideas on how to put some form of charging point in under the bonnet? Had thought about mounting a couple of brass posts like a battery but would ideally need some form of cover on them and would need mounting with an insulating material....not sure if theirs anything can buy like that?
    Cheers PT
  6. <tuffty/>
    21,251
    3,879
  7. StaceyS3
    2,505
    502
    You sir are a diamond :)
  8. Ste_Nova
    Ste_Nova Active Member
    1,223
    47
    for the jump start point use A6 parts
    as seen here on the top left, i'll go and take a better pic of mine in a min
  9. Ste_Nova
    1,223
    47
  10. jcs356
    jcs356 Brum brum
    2,726
    67
    My old Ibiza, but you get the idea....
  11. StaceyS3
    2,505
    502
    Cheers guys they both look like very good ways of doing it :)
    Will enquire on how much the a6 one is later ;)
  12. Prawn
    11,532
    3,471
    Guys, I'm soon to be doing this myself, and the ONLY bit im unsure on is the crimping of such large terminals.
    What crimps do people use? Looking for the best low cost option!
  13. <tuffty/>
    21,251
    3,879
    I can do it for you...
  14. IH786
    IH786 Member
    146
    I like the idea of the jump start points - does anyone have the part numbers??
    I have the battery relocated on my LCR. The battery is in the wheel well - which is covered with a sheet of MDF. Would not be easy to jump start it from there!
    I didn't have access to a crimp tool so just used a big vice to crush the terminal into the cable - worked well :)
  15. <tuffty/>
    21,251
    3,879
    Crimping 'cold welds' the the crimp to the cable... there isn't enough pressure available to do this using a vice and will create a connection that is not as effective electrically... creates a smaller contact area between the cable and the crimp which will generate more heat at the joint on higher amperage loads..
  16. Prawn
    11,532
    3,471
    that is an awfully Generous offer mr PT. It would either mean a trip to Gloucester to relocate my battery or working out lengths before hand and taking a chance that they'll work.
    Hmmmmmmmmmmmmmm
  17. Scullies
    Scullies Well-Known Member
    1,543
    657
    I use a circuit breaker fitted near the battery. There is a lot of cable running through the car up to the starter, that has the potential to become a fire hazard. Seen it too many times on boats.
    My guess if it did happen to catch fire, insurance wouldnt cover it as its been "modified" - we all know how insurance companies are, any loop hole to get out of paying.
  18. <tuffty/>
    21,251
    3,879
    Depends if all mods have been declared which mine have...
    Fairly sure the TT 3.2 V6 (which has a factory relocated battery) doesn't run a fuse but I will get that confirmed... if it does then I will source an appropriate setup and apply it to mine...
  19. IH786
    IH786 Member
    146
    i did use a big vice so must have been a decent amount of pressure :)
    Fair point tho - a crimp tool costs too much for a one off job so had to bodge it - runs ok so far!
    Am also running a fuse too
  20. <tuffty/>
    21,251
    3,879
    Might be an idea to consider soldering the terminal... plumbers style blow torch or similar would do or very high wattage soldering iron might work
    Its no worse that those crappy battery terminals that secure the cable with screws but they are really only designed for short run lower amp/cable gauge stuff... poor connections like this promote corrosion and leads to poor electrical conductivity...
  21. Ronin225
    Ronin225 SEAT owner
    81
    Heres mine (albeit in a leon) i added an inline kill switch too
  22. StaceyS3
    2,505
    502
    Cheers for all your replys peeps :)
    Battery and terminal blocks that PT posted up arrived, looking at the terminal block I think I will wait and see where I end up mounting it as that can be used to jump start off unless I put it somewhere inaccessible
  23. Prawn
    11,532
    3,471
    open the cover and just clamp onto the stud?
    You don't appear to have much faith in your battery Stacey :p all this talk of jump starting!
  24. StaceyS3
    2,505
    502
    Yeah that's the plan as should be sufficient if needed
    I have faith it's more as its going to be located in a place I wouldn't like to have to get to should the sh1t hit the fan ;)
    My current battery is 550cca and 59Amp hour where as the odyssey is 500cca and 45amp hour so shouldn't really notice to much difference I hope?
  25. Prawn
    11,532
    3,471
    I run a £29 6kg 20aH mobility scooter battery, and even after parking it up for two weeks in the snow, then working on the car with radio on all day, it still started it perfectly. I don't think you've got anything to worry about mate!
    If anything, my only concern would be that you've spent more money than you needed to on a battery that's bigger and heavier than it needs to be!
  26. Prawn
    11,532
    3,471
    On a slightly more serious note though, where do you guys pass these massive cables through the bulkhead?
    My bonnet pull cable gromet has a vac line through it for the boost gauge and WMI, and the one opposite by the pollen filter has the WMI hard line through it and wire for my N75 switch.
    I'm really unsure where to try and pass the new battery cable through. Is there any scope to cheat and drill the heater casing near the top and have it coming out through the pollen filter?
    Anyone tried one of these???
    Longacre Battery Bulkhead Through Panel Electrical Cable Connector Race Rally | eBay
  27. StaceyS3
    2,505
    502
    Tbh the only reason I bought another battery is due to size rather than the weight saving side of things
    The problem being is my mrs still uses my car regularly so won't be as conscious as me about it and I also use my car to charge things when I go fishing so that was why I got the biggest capacity small battery I could find ;)
    The original battery does actually fit like a glove where I'm relocating it to but doesn't allow room to hold it down as securely as I would like without hacking parts of the car out and not overly happy with it completely filling the void
  28. StaceyS3
    2,505
    502
    I'm yet to cross this obstacle but I already have a 4awg cable in the place that the new one will be run so will just use that to pass it through
    That connector does look like a good solution if cant fit it through the grommet
  29. Prawn
    11,532
    3,471
    which grommet does yours go through currently stacey?
  30. StaceyS3
    2,505
    502
    The pollen filter one with my 6mm WMi line....so will be tight but should hopefully be able to pull it through?
  31. Andrew@A.L.D
    3,879
    617
    I'm fitting a small race battery. I'll post pictures when done, I'm only doing if so I can get a better cold air feed to the filter
  32. StaceyS3
    2,505
    502
    I would have thought it will definately benefit from that area being nice and open for airflow
    I'm doing it for a few reasons including a bigger filter, better airflow, better pipework route as mines still 60mm and last but not least the room in the bay would be brilliant :)
  33. Scullies
    1,543
    657
    there is space in the grommet where the main wire harness goes through the firewall. I managed to get 50mm sq cable through it safely.
    There is also a stud the you can install through the firewall but requires a hole to be drilled through the firewall
    Red HD Battery Terminal Stud Firewall Feed Thru | eBay
  34. Andrew@A.L.D
    3,879
    617
  35. Prawn
    11,532
    3,471
    Thanks mate, that's great.
    I'm going to ask a REALLY silly question now though: Where does the main loom go through the bulkhead?
    I had the scuttle off at the weekend to have a nose around, and it looked like the main loom disappeared inside a plastic sealed box under my wiper mechanism. Did you remove the wiper mech to get into that box and route the cable there?
    Said box on my car is at the cambelt side of the engine bay.
  36. <tuffty/>
    21,251
    3,879
    Main loom goes through that box mate... my boost gauge and cruise control wiring goes through it
  37. Scullies
    1,543
    657
    My car is LHD, but I guess it's the same on a rhd. If you remove the drivers dash and look up behind the fuse box you should see where the harness goes through the firewall. In the engine bay, it comes through the firewall just above the brake booster, if I remember correctly. From there you can route it into the "harness carrier" with the rest of the wires.
    This might be different on rhd, so you can't hold me to it :moa:
  38. StaceyS3
    2,505
    502
    Copied and pasted from my build thread to complete the thread :)
    Have finished my battery relocation today and am pretty chuffed and the engine bay has so much more room for more important stuff 😉
    The standard battery does fit in there with the panel back on but it didn't leave any room for mounting brackets and personally would like a bit of a gap in the area incase get t-boned
    Pulling the cable through was a pita but ended up tapering the conductor and used a bit of oil to aid it
    Empty battery tray
    Took the fusebox apart to look where was best to bolt it down but have ended up sticking it with some silicone to the bracket
    Will get some better pics when it's dry
    Some pics of the battery bracket and install
    Just for reference as someone had asked about crimping the lugs on here's the crimping tool that I used
  39. Ste_Nova
    1,223
    47
    on my a6 with the battery in the spare wheel well it has an explosive disconnector controled by the airbag ecu afaik
    StaceyS3 likes this.
  40. Ronin225
    Ronin225 SEAT owner
    81
    Thats where i was originally going to locate my battery however the leon boot design cant quite accommodate the OE battery there
