Battery Fault? Help needed
ElliottB Aug 25, 2013
  1. ElliottB
    ElliottB Audi A3
    198
    Evening guys.
    Just gone to start my car (audi a3 2.0 TDI) and it wouldnt start and was clicking loads, then it came up on the panel "battery level low" so i took battery cover off and looked at the indicator and that shows as clear so means i need a new battery but, it is also coming up with ESP fault see manual and power steering is heavy but is that because of the low battery?
  2. hades-
    9,482
    646
    low batt will cause ESP fault after a short drive it will clear
    reepers likes this.
  3. Chillout
    Chillout Active Member
    610
    50
    Jump the car and drive it also get your battery tested to rule out alternator
  4. reepers
    reepers Member
    110
    15
    Grab a new battery from Eurocarparts or such, get a higher power batt than standard too. I replaced mine not long ago to a Bosch S5 - same symptoms as you.
  5. ElliottB
    ElliottB Audi A3
    198
    I am going to ring euro car parts up in the morning and see if they are open as i have to drive to work tuesday so fingers crossed i can go get one tomorrow
  6. Chillout
    610
    50
    They have a offer on this weekend so click and collect might be the way to play.
  7. ElliottB
    ElliottB Audi A3
    198
    I saw that mate going to do click and collect in morning and hopefully they open! will ring first
