Battery drain issue. Anything to worry about?
sidibear Jun 10, 2013
  1. sidibear
    sidibear Looking for Zombies !! Staff Member Moderator Audi A4
    2,320
    768
    B7 08 A4 S-Line Avant 2.0tdi.
    Used it last Saturday and did a fair bit of mileage. Used it Tuesday night and drove about 1 mile, drove back the same distance later but with the lights on.
    Same trip Thursday night. Came to drive it Saturday and it cranked too slow to start, fired up fine after a jump start and drove a total of around 50 miles during the day with shopping and all that. Other than Tuesday and Thursday nights low milage it just sat outside.
    Yesterday morning it started fine, drove for 200 miles and when I came to come back 200 it started no problem
    Do you think the failure to start is down to the battery not getting enough charge when I used it during the week, or could it be something more sinister?
  2. NHN
    29,352
    1,720
    Not again, lol.
    How olds the battery?
    Ideally you should whack a ctek on it to charge over night properly as these chargers are very good indeed, check voltages & see how it drops, check voltages wen running, when cars of etc.
  3. Broken Byzan
    13,237
    465
    do you leave the camera on all the time? That was only change to avant and in a week battery was flat.
  4. NHN
    29,352
    1,720
    I forgot he had a cam, could very well be contributing, but whats the load?
  5. sidibear
    2,320
    768
    The battery is original and yes the cam is on all the time. It has happened twice now, first time was due to voltage drain caused by faulty sat nav that was fixed, its been ok since then until last Saturday. Just curious as to if its a random fault that is starting to occur.
    Cant leave a charger on its as it parked in the street.
  6. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,162
    1,123
    Its a 5 year old batter and with your camera on all the time you might have pushed it over the edge a little bit.
    Could do a drop test on the battery and see if its losing charge or if its something is draining it with the keys out.
    I'd even be tempted to put a new battery in it.
  7. NHN
    29,352
    1,720
    If you use the ctek it will analyse & can make some older batteries come back to life with its 8 step charging system, I use them & they're brilliant, I would do this before new battery, if I wasn't using mine I would let you borrow it mate, but the mxs 10 is also a 12v supply unit so handy for work.
  8. Molnboman
    Molnboman Well-Known Member
    1,338
    193
    A five year old battery?....lucky chap! My money would be on that battery being gubbed or on the way out at least.
    A
  9. sidibear
    2,320
    768
    I am going to leave until tomorrow morning, it had a good run yesterday so if it doesn't start tomorrow I will get a new battery put on it. If it does then I will try going a longer route home to get a bit more charge into when I go out,
