battery disconnect ?
Kingfisher Sep 2, 2012
  1. Kingfisher
    Kingfisher Active Member
    285
    53
    This applies to many Audis but..... about to replace battery in an A4.
    I've read somewhere that if you connect a 12v supply to the ciggy lighter it maintains 12v through the car as that socket is permanently live thereby keeping radio codes, computer etc etc etc happy !
    Is this correct?
  2. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,163
    1,123
    The 12v socket is a permanent live.
    I guess could work.
    Not sure 100% my self.
  3. aragorn
    18,491
    855
    yeh should work.
  4. Kingfisher
    285
    53
    I'll let you all know ........
  5. aragorn
    18,491
    855
    You could also just clip a battery charger onto the battery leads.
    Either way, you'll need to make sure the live lead doesnt touch the bodyshell or any other metal parts around there, or you'll short out your power source.
  6. Kingfisher
    285
    53
    Yes, I think that was what I did last time -- and wasn't that happy as there is potential for a mishap! Hence the 'plug something in' thoughts...
  7. aragorn
    18,491
    855
    well the plugged in fag lighter doesnt remove that potential mishap. The live battery cable will still be live, and will still short out the power supply if you touch it against the chassis when powering the car from the fag lighter.
