battery coding/advice
vw754 Mar 4, 2013
  1. vw754
    vw754 vorsprung Durch Technik
    2,325
    58
    My q7 3.0 tdi.........is draining the battery,its ok if i go to it 12/13 hours later but after that its flat !
    Ive been told by audi i can charge it via points under the bonnet,which im doing now.........i have vcds how can i check if something is draining it or the batterys shot?
    Audi replaced it in may 2011 so its not 2 years old yet
    Like i said i have vcds,but dont know how test whats draining it etc........please help.
    also how do i recode new one?
  2. NHN
    29,300
    1,702
    Why not ask Ross-tech for help if you have VCDS.
  3. vw754
    2,325
    58
    good thinking ! il do that now.
  4. NHN
    29,300
    1,702
    Only if you have a genuine interface.
  5. vw754
    2,325
    58
    that i do have...i love genuine !
  6. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    Have you checked the Battery is correct for your vehicle?
    You can check battery through vcds. See what voltage it is with ignition off/running. Any lights in boot turned on ?
  7. vw754
    2,325
    58
    with ign on it was dropping to 1180 ish.....with engine running it was 14.15v and generator 14.30
    i removed the battery from the car yesterday and it was this battery.......Halfords | Halfords Lead Acid Battery HB019.
    dated 05/12
    its not coded some other battery is.....i think a varta one,as i checked with vcds,i removed it and charged it on max charge for 5 hours yesterday.....il re-check it tomorrow see if its getting flat
  8. vw754
    2,325
    58
