Battery charging voltage
stevebuba Mar 26, 2011
  1. stevebuba
    stevebuba New Member
    17
    Does anyone know what the above is for a 2 litre fsi?
  2. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,249
    192
    Most cars are 14.6
  3. stevebuba
    17
    Mine is charging at 13.8 so could the alternator be faulty?
  4. Woorlord
    Woorlord shifting to Hyperspace... . VCDS Map User
    951
    17
    According to Audi Workshop Manual Charging Voltage must not exceed 14.4V, and.....
    A battery terminal voltage of 12.5V is expected to be normal at no load. (i.e. measure with a voltmeter with the negative terminal cable disconnected.)
    A no-load voltage between 11.6V~12.2V would indicate a totally discharged battery.
    I checked my charging voltage and it is 14.2V. I would have thought a 13.8V charging voltage should be OK.
  5. scott b
    scott b Active Member VCDS Map User
    1,254
    13.8 - 14.4 is normal
  6. stevebuba
    17
    Yeah alternator seems to be ok, but battery is dead. Just replaced it with a new BOSCH not the easiest job in the world, trying to get to the 6mm allen bolt at the front of the battery is a real pain first you have to remove the rubber seal on the secondary firewall, then lift the clips on the foam cable thingy and then you can just about get a 1/4" drive allen socket on it, but if your short like me i had to kneel on the engine to reach!!!!
