battery charge problem
imported_jamesgo Jul 25, 2004
  1. imported_jamesgo
    imported_jamesgo Guest
    hello,
    i was wondering if anyone has suggestions to solving a problem w/ my TT. i tried to start it wenesday after not driving it for five days. it would not start, the battery was completely dead. i jumped started it, but strangely the tach., speedometer, fuel & temp. gauges, trip computer, clock do not work. the parking brake light stays on constantly when disengaged and the oil sensor doesn't work since i am getting a oil level warning and the oil level is fine. i live in miami and someone suggested that not driving it for five days in addition to temperatures always around 32-35 everyday may have contributed to the battery losing its charge. i am taking it to the dealer, but wanted to know if anyone has heard of this problem, and how did you fix it??
    thank you...from miami
  2. scoTTy
    scoTTy Active Member
    1,962
    The only time I've come across this sort of thing is when people have wired something extra in. GPS Tracking/security devices seem popular causes.
    Audi certainly wouldn't sell a car that you can't park for 5 days. Strangely, it's normally cold temps that kill batteries when I am.
  3. imported_jamesgo
    I have not wired anything extra, and I doubt that letting the car sit five days would kill the battery....i commonly leave the car sit 3 days each week when i travel for work....i'm taking it to AUDI tommorow...hopefully it is something simple..i'm just confused why the instument cluster doesn't work...thanks
  4. peteA3tdi
    peteA3tdi Member
    408
    change the battery it sounds like the lead plates are shorting and zapping all the power this can blow the ecu,dash ect ect
  5. peteA3tdi
    peteA3tdi Member
    408
    did they do a draw off test? (to test for any thing draining the battery ) if you have a volt meter its very easy with the engine off and key out of the car (the doors can lock when you reconect the battery) take off the grd lead off the battery hold one wire from the volt meter on the grd pin on the battery and the other wire from the volt meter on the wires you took off the battery on the volt meter anything more then about 0.5 volts and something is staying on and draining the battery hope this makes sence ps don't forget to reconect the battery after the test
    or if you are still having problems as batterys are fairly cheap just replace it
  6. neil.c
    neil.c Senior
    568
    Pete your information is incorrect you do not measure voltage in series with the battery, you measure it in parallel.
    You measure current in series, amps or milliamps.
