Basic K04 upgrade (360ish BHP std injectors to start with)
Nez Jul 28, 2009
  1. Nez
    Nez Member
    598
    Hi guys need help :( just want to know much all these parts worth and they all second hand not new.
    RS4 K04 Turbocharger, left 078 145 703 M (5304 988
    0025)
    RS4 K04 Turbocharger, right 078 145 704 M (5304 988
    0026)
    induction pipe RH (Turbo inlet pipe) 078133610H
    induction pipe LH (Turbo inlet pipe) 078133609H
    induction pipe RH (up-pipe) 078133610G
    induction pipe LH (up pipe) 078133609G
    induction pipe connecting hose - 2 off 078 145 719 P
    turbo-downpipe gaskets – 2 off 8D0 253 115 F
    turbo-downpipe nuts - 8 off N 903 690 01
    turbo-downpipe studs – 8 off N 907 787 01
    turbo oil line gaskets – 2 off 058 145 757 B
    exhaust manifold to turbo gaskets - 2 off 078 145 039
    oil feed pipes
    RS4 clutch and pressure plate
    Any help would be great ok waiting for the replies :)
  2. stapo69
    stapo69 All hail the mighty quattro!
    969
    Are you selling or buying? Cos if you're selling they're worth about £50 and a pint!
  3. Fraser
    Fraser Member
    584
    depends on the condition and miles put on the ko4s
  4. Nez
    Nez Member
    598
    I am buying all these parts and the guy is offered me £750 Incl postage for everything is it worth it?
  5. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    depending on condition....hell yes.
    pair of second hand rs4 turbos alone went for that on ebay not that long ago.
    I would check the turbos very carefully though, even get someone else to look at them if possible.
    expensive rebuild if shot
  6. aragorn
    18,040
    726
    the chap in poland that mark used was doing very reasonably priced rebuilds...
  7. Lee Goodall
    Lee Goodall Active Member
    2,279
    Yeah have a word with Sean at Scroll Products.. he is very reasonable.
  8. Nez
    Nez Member
    598
    How much is the rebuild for the turbos ? and also does anyone knows anyone who can fit these for me for cheap price :wacko:
  9. Lee Goodall
    2,279
    Email for prices mate.. FAO Sean K (Kinch I think)
    info@scrollproducts.com
    Don't think fitting will be cheap on an S4 whoever does it mate.
  10. Nez
    Nez Member
    598
    How much is the cost for the fitting?
  11. aragorn
    18,040
    726
    I more meant that if the blowers do happen to be iffy then they can be fixed for a reasonable price.
    Its a good price for the parts i guess, to get all the fixtures and fittings etc is good!.
    As for fitting, its an engine out job. So your talking at least 1 maybe 2 days labour.
  12. Lee Goodall
    2,279
    If get the turbos checked before fitting then you'll know if it'll be in your favour to have them rebuilt first or not.
    Be very expensive if you pay for fitting and then they die only to be taken off rebuilt and fitted again.
  13. docurley
    4,070
    85
    To fit just the turbo's is an engine out job so exspect to pay around £900+ and the rest would just be fitted in replace ment of the old stuff the clutch would not be much more I would have thought due to the engine being out anyways.
  14. jonnya
    jonnya Member
    102
    It's a good price I think, even factoring in a rebuild for the turbos.
  15. Nez
    Nez Member
    598
    Thanks for the replice guys :) ok send a email to the guy and here is the reply:The engine mileage was 35000. The engine, turbos, etc ...all are in perfect order
    Onething I am worried is he wants the money wire transfer payment should I trust this guy and if I get any problems can ask the bank to take the money back from his account?
  16. aragorn
    18,040
    726
    If you wire the money and he screws you, then your screwed, and you'll be unlikely to see your money again.
    Either use something with a bit of protection, like paypal, or go collect the parts.
    An alternative might be to find someone on here who lives local, get them to check the parts are real and/or collect them, then forward them on.
  17. Nez
    Nez Member
    598
    Yea I am not going to sending the money like that I will collect it :) I can't trust this guy.
  18. Sir Chumpalot
    Sir Chumpalot Member
    88
    As aragorn said, do not send the money via BT, I did this and go absolutely shafted. My bank didn't want to know and couldn't help me either :( In the end I had to contact the police.
