Bang & Olufsen hifi retrofit
woollyjoe Jan 2, 2014
  1. woollyjoe
    woollyjoe Active Member
    410
    45
    Hi all, anyone attempting retrofitting hifi.
    Have a a chance to get the bang olufsen system for my A6 and whilst I have no issue installing the speakers, amp and other box, my concern is the wiring loom and coding the car that it had a b&o hifi and the tweeters pop up.
    Any by advice from this or similar is appreciated.
  2. elan2s
    elan2s Active Member
    343
    40
    I would imagine this is a massive task and your car will almost certainly not have the correct wiring for the system. You would definitely have to code the car but that should just be a case of using VCDS and would probably be the least of your challenges
  3. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter Audi Main Dealer
    27,286
    10,248
    We have site sponsor NHN who does retrofitting and would also be able to code at the same time. May be worth dropping him a pm for a price. Where are you located? :) x
    NHN likes this.
  4. NHN
    29,413
    1,740
    I wouldn't agree tbh, that sometimes is the task & with newer cars, the issues are when it goes into Audi, they download the cars original spec/coding & it reverts any changes, I'm sure it would need component protection removed by audi when parts are fitted.
    To be able to assess wiring, I'd need vin details to check what's fitted now & its not a quick conversion, but anything's possible.
  5. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    You do know how much it is for a factory option let alone retrofit price?!
  6. woollyjoe
    410
    45
    Just giving this another nudge. Has anyone got any experience retrofitting oem Hifi, and if anyone can recommend anyone who would be up for trying to fit this? Someone who knows their way round the software, although I get there is a lot of time should wiring looms need changing etc. Thanks
  7. NHN
    29,413
    1,740
    Yes, but as stated, its a vast cost to do this in time, wiring etc.
  8. Cruiser89
    Cruiser89 Advanced In Car Tech Site Sponsor
    1,484
    222
    Having got this car (14 Plate) and knowing what is installed and required it's not worth your time or any installers time if I'm honest... It's pretty complex and agree with NHN.
    From memory, factory price was something crazy like £8k from memory. The Bose system is however incredible if you already have that.
  9. woollyjoe
    410
    45
    Thanks for feedback. I've found a company that has done this before. They've suggested the car will be with them for the week. Just waiting on cost, but I can live without the car for a week to get his done. Especially as it will be cheaper than buying the option from factory (I can get the bits relatively cheap which is the bulk of the original cost).
    Is there anything you would do at the same time?
    I am installing GoPro's by the rear view mirror and one on the back shelf, and will need power (mini USB) if this can be wired easily? Was thinking power can be got from the rear view mirror? or will this have to be run round windscreen to fuse box? Same for rear shelf - was thinking there is a cigarette socket power can be taken from and cable ran discreetly?
  10. Cruiser89
    1,484
    222
    Hmmm - It's not an install I would be willing to do so good luck to them :)
    Are you going to use the GoPros only for track days or as a DashCam? I'm not sure I would use them as a DashCam as they were never designed for constant recording like that. Don't even think they have a loop facility. Whichever way you go it's best to go to the fusebox.
  11. woollyjoe
    410
    45
    I'm curious why you wouldn't do the install? You do retrofits for a living and you do say "advanced" in your company name
    The Gopro has looping function you can set from 5 mins up to entire memory. It also has wifi and can be controlled via iphone. I can also use for other things when not in the car.
  12. a6_chris
    1,883
    160
    Before commiting to this think about how your warranty may be affected.
  13. woollyjoe
    410
    45
    I have spoke with the dealer. As long as nothing that needs warrantying relates to the hifi I am fine. If there is an issue relating to hifi they obviously won't cover that which is fine with me. There isn't any splicing or non OEM wiring that is going in. It's no different to the other mods being done by many others. The main issue I have is the software.
    The dealer seemed more curious than against it as I had to enquire about getting the hifi itself and the wiring looms, although yet to establish if the separate wiring looms are needed.
