BAM S3 full rebuild for Hybrid or BT
hoffmanvp3 Sep 18, 2013
  1. hoffmanvp3
    hoffmanvp3 Active Member VCDS Map User
    304
    81
    Cheers buddy:)
    well for every one else.....the saga continues
    Ring gaping
    followed by plastigauging the big end oil clearance
    All within spec so on to clocking the rings and sliding the pistons into their respective bores
    New oil pump c/w new pick up line and chain tensioner
    the white numbers is for main cap order and which orientation
    New front and rear crank oil seal flange
    This one was a pita to fit due to the inward fold of the seal that surrounds the flywheel mount. The fold has to be folded over the flywheel mount without getting caught and being bent back on itself. Had to remove the engine stand in the end as it kept folding outward rather than inward.
    Sump on and sealed
    ARP head stud kit in
    Any body with experience with this head stud kit know if you gotta re-torque the nuts after a couple hundred miles?
    And because I could lol
  2. Andrew@A.L.D
    3,879
    617
    My advice with the studs it to double check anyway but install them after you fit the head as it will be very hard in situ in the bay
    Scullies likes this.
  3. hoffmanvp3
    304
    81
    I'll be throwing the engine back in the bay with the head on as it's easier for me. Same way it came out:)
  4. hoffmanvp3
    304
    81
    Just wanted to let potential people who will be re building there motors that Permatex assembly lube is awesome!! Poured some into the oil pump gear chamber and oil pump chain to eliminate metal to metal pumping will the oil pump primes itself during the first start.
    Highly recommended:)
    On a different note, what engine oil are engine builders on here using to run in the new motor?
    cheers
  5. badger5
    9,488
    1,999
    10w40mineral for first start and running, then 10w40 semi for rest of running in, then whatevers suited to the motors spec thereafter
  6. hoffmanvp3
    304
    81
    Cheers Bill
    how long you recommend the "running in" process for and the stages of the mineral oil then semi?
  7. hoffmanvp3
    304
    81
    Thinking 100 miles for the mineral oil then 500 for semi?
    then fully syth there after
    presuming my engine last 500 miles lol
  8. Scullies
    Scullies Well-Known Member
    1,543
    657
    have you fitted the head studs yet. Im curious to see how the nut sits as with the bolt version the head of the bolt sits inside a recess in the head.
  9. hoffmanvp3
    304
    81
    The Stud kit has a counter sunk nut which is a star head. Haven't got the head back yet. Been told it's this week but I'm back out to Kuwait mid week so will have to wait:(
    Ill post pics of me nuts if u like :hubbahubba: Lol
  10. badger5
    9,488
    1,999
  11. aragorn
    18,373
    829
    I based my running in on that guide bill linked. Everyone has their own methods but this is what i did:
    10w40 mineral oil (cheapest i could find, got it from Wilkos)
    N75 disconnected. Freshly built engine, started it and immediately drove it round the block a few times. Stopping (but not shutting it off) after each lap to check for leaks as it came up to temperature. Once it reached 90 degrees and i was satisfied the stat had opened i stopped and checked the coolant and oil levels were acceptable. Then took it out on the road.
    I figured out a route which was about 25miles long, but out in the country on open roads where i wasnt going to get stuck in traffic or at lights etc, and i started doing pulls thru the rev range, starting at 50% throttle and going from about 2k to 4k in third, then lifting and letting it coast back down thru the revs in gear and driving gently for a minute or so before the next pull, and slowly increasing throttle angle and RPM's with each pull. After about 10-15miles i was doing full throttle 2k to 6k pulls, and did these at sensible intervals as the road allowed on the way home, coasting back down the revs each time.
    After this i got home and changed the oil, which looked like glitter which worried me a bit, but it seems to have had no lasting effects! I changed the oil again using the same 10w40 mineral oil at 100miles, then 250, 500 and 750 before switching to fully synth at around 1000 and reconnecting the N75 at the same time.
    After the first 25miles i just drove the car normally. I avoided steady state running as much as possible (ie just sitting on the motorway at 70mph for an hour...) however it did get some of that and i just tried to vary the load as much as possible.
    I suspect you could easily switch to fully synth and full boost at 500miles.
  12. Westy
    Westy Well-Known Member
    17,443
    1,104
    I followed that link too but te problem comes when you have a great big air lock that you have to clear before going out on the road. My motor was running in the garage for a while so I could clear the air an get the coolant sorted.
  13. aragorn
    18,373
    829
    I've obviously been lucky as i've never had an airlock on these engines. Fill coolant, wait till it vanishes, fill coolant, wait till it vanishes, repeat continuously for a couple of hours as your doing the rest of the buttoning up steps and thats it. Start, drive. I typically dont even need to top it up after.
    I suspect if you try to glug all the coolant in in one go, minutes before starting it, then your going to have issues, as due to the stat being closed it takes ages to seep all round the engine, so you end up with a motor thats actually only half full.
  14. hoffmanvp3
    304
    81
    Yea ive read that before when i was running in my bike.
    But run in a new engine and gearbox hard ie brand new car and the gearbox will pay the price imho
    But my gearbox is old so will prob run it hard:)
    plenty of power on/off with engine braking and fresh filter at 500miles and again 1K will be the ticket me thinks
  15. aragorn
    18,373
    829
    I changed the filter with the oil every time.
    The amount of **** in the oil the first twice it was dropped out theres no way i'd be wanting to keep that filter in there any longer.
  16. hoffmanvp3
    304
    81
    Good point, there only pennies any way from TPS:)
  17. Westy
    17,443
    1,104
    I second this. I also used a magnetic sump plug as that'll catch all the metal filings.
  18. aragorn
    18,373
    829
    TPS? goto your local motorfactors and they're cheaper still.
  19. hoffmanvp3
    304
    81
    I get specail prices at tps for me:)
    keep forgetting to buy a magnetic sump plug, ive put it on my list!
    Was also gonna try and port the standard exhaust manifold as thats starting to crack so ive nothing to loose if i trash it lol, as i want to run the engine back in with the KO4 before running more power.
  20. badger5
    9,488
    1,999
    beware of ecs ones.. every sump I've seen with one of these in is leaking from it
  21. hoffmanvp3
    304
    81
    Good call there Bill as was gonna order one.
    They look aluminium due to being anodised so will be soft as ****e and will prob strech after the first use
  22. hoffmanvp3
    304
    81
    I`ll just get a magnet and stick it on the out side of my oem drain plug:)
  23. Westy
    17,443
    1,104
    Mine isn't :moa:
  24. hoffmanvp3
    304
    81
    Must be people over torquing them on
  25. Scullies
    1,543
    657
    I have found its easier to fill the block with coolant via the coolant reservoir, then remove the upper radiator hose and keep it as high as possible, then fill the radiator up with coolant. I use a funnel attached to a piece of hose that fits over the radiator fitting. Fill it up, then quickly fit the radiator hose back on, its messy but works every time.
    Last thing you want to do is to over heat the engine while the radiator is empty :crying:
    Westy likes this.
  26. Scullies
    1,543
    657
    the ECS one i had was steel, so it eats through the sump thread very easily.
    I have welded a AN o-ring boss onto the sump and fitted the o-ring AN fitting. No leaks and its not so easy to cross thread an AN fitting.
  27. hoffmanvp3
    304
    81
    Here's the ARP nuts for my head stud kit scullies
  28. hoffmanvp3
    304
    81
    We'll look what turned up in the mail today :)
    Pipewerx 3" down pipe and sports cat, going Hybrid as where moving in dec and can't afford a whole Garrett kit due to solicitor fees and the missus is going mad with the S3 build which I'm really gutted but a hybrid KO4 will get the car close to what I want and maybe in the future I'll go Garrett. Just need the LOBA320 and I'll be happy with that
  29. Prawn
    11,532
    3,470
    what's a LOBA320 Hoff?
    Have you looked at / spoken to beachbuggyturbos at all?
  30. hoffmanvp3
    304
    81
    It's a Hybrid stage 4 KO4 LOBA offer for the 8L S3.
    Spoke to beach buggy but he's still working on the kit. Think he said the AC pipe work gets in the way but can't remember.
    His set up will cost more than I've got left so making the most with of what I have left:(
  31. hoffmanvp3
    304
    81
  32. hoffmanvp3
    304
    81
    I'm aware the limiting factor of this turbo choice is the manifold but I'll see if I can port it.
  33. hoffmanvp3
    304
    81
    Hang about. What's this I see:) I'll be calling in the morn for one of these. Half the price of the LOBA!!
    K418t Hybrid
  34. <tuffty/>
    21,238
    3,877
  35. hoffmanvp3
    304
    81
    yea read it, some very good results there but dont have WMI and i must admit im a bit sheepish getting it after reading posts of people with leaking nrv`s in the AEM kit
  36. badger5
    9,488
    1,999
    buy the right kit then dude :)
    Devils Own, basic kit + solenoid upgrade
    thats what I am using now.
    AEM sadly have gone down the pan in terms of whats being sold and reliability issues on check valves and controllers.. Shame as it was an excellent spec kit for the £
    If you do go hybrid based turbo, WMI will enable it to achieve good results. Heat Management on anything k04 based is key
    Westy likes this.
  37. hoffmanvp3
    304
    81
    Good plan there lol
    Ill have a look into the Devils own kit and see:)
    Just dont want my fmic full of meth when i start it in the morn:(......BOOM YA ******* lol
  38. Prawn
    11,532
    3,470
    Chap, it would appear you have your wires very much crossed and heading in totally differernt directions on the wrong tracks....
    The Loba turbo you speak of, the horribly over priced one, is ko4-023 fitment. Beachbuggy already offer a direct alternative, and have done for a very long time, I'd also place bets on it being better than the over priced Loba one.
    The kit you speak of that Dan questions AC pipe clearence, is an entirely different project using a turbo from a TFSI engine the K04 064, which is in no way related to a k04-023, and not all linked in any way to the Loba 320 and Beachbuggy ko4 023 hybrids.
    You really would be somewhat crazy to buy the Loba one given what's available closer to home for half the cost....
  39. hoffmanvp3
    304
    81
    Oh believe me i was very much eating my own cake last night when i found that BBT hybrid and Bills mapping results from his Hybrid.
    Ive emailed BBT but havent had a reply yet as i couldnt belive the cost difference between the LOBA and BBT.
    Will deff be going for the BBT hybrid now but just waiting for him to reply
  40. hoffmanvp3
    304
    81
    Well had a very nice conversation with Dan and have ordered the K418t Hybrid but hes having to source a new unit for me though as mines cracked right through the hot side so no point investing into a nackered unit
