BAM Crankshaft Tolerances
hoffmanvp3
Oldmeldrum
Just a quick one chaps.
Does any one with ElsaWin spare a few minutes and tell my the various service limits to the BAM crank shaft?
I believe VAG offer a over size shell for the crank casing section if they require over size machining? The yellow shell?
And vise verso with the connecting rod section of the crank.
Cheers much appreciated.
I might be able to help you tomorrow mate.. waiting for my copy to arrive (due anytime...)
that's if no one replies today.
hopefully this is what your after, for a bam engine code
Crankshaft dimensions
Up to approx. 05.2000
Honing dimension
(in mm)
Crankshaft main
bearing journal Ø
Conrod
bearing journal Ø
Basic dimension54.00–0.022
–0.042
47.80–0.022
–0.042
1st undersize53.75–0.022
–0.042
47.55–0.022
–0.042
2nd undersize53.50–0.022
–0.042
47.30–0.022
–0.042
3rd undersize53.25–0.022
–0.042
47.05–0.022
–0.042
From approx. 05.2000
Honing dimension
(in mm)
Crankshaft main
bearing journal Ø
Conrod
bearing journal Ø
Basic dimension54.00–0.017
–0.037
47.80–0.022
–0.042
1st undersize53.75–0.017
–0.037
47.55–0.022
–0.042
2nd undersize53.50–0.017
–0.037
47.30–0.022
–0.042
3rd undersize53.25–0.017
–0.037
47.05–0.022
–0.042
Thats part of the info im after.
Was there any more info that came with those Dims Cooper? how to`s e,t,c
That was the only info in that section for the crank, i'll check for any more tonight tho when i get home ;-)
Thanks cooper
Some thing to do with the colour coding of the OEM replacement bearing shells for the crank and con rods.
Basically if my crank is needing machined due to ware then i need the info on what size to machine it down too the the appropriate dim then there is a range of OEM replacement bearing Shells to use after the machining had been completed.
Hope that made sense lol.
cheers
Honing dimension
(in mm)
Crankshaft main
bearing journal Ø
Conrod
bearing journal Ø
–0.042
47.80–0.022
–0.042
–0.042
47.55–0.022
–0.042
–0.042
47.30–0.022
–0.042
–0.042
47.05–0.022
–0.042
Honing dimension
(in mm)
Crankshaft main
bearing journal Ø
Conrod
bearing journal Ø
–0.037
47.80–0.022
–0.042
–0.037
47.55–0.022
–0.042
–0.037
47.30–0.022
–0.042
–0.037
47.05–0.022
–0.042
interesting how the tolerances vary with model year?
wonder why?
well mines a 2003 BAM S3 so im guessing the 5.2000 on wards is me:)
I guess i`ll just hope my cranks journals are within sped when i strip the motor.
Its had a full service history so im guessing the shells will ware first.
I`ll be plasti-gauging every journal just to be safe.
Does every one just use the green one?
Isn't is supposed to be the white?
The PL-X plasi gauge Cooper?
Thought the green wasn't small enough graduations?
Not to sure on the measurements or even if it is a green set, its been sat in my tool box for awhile, will check what set it is an the measurements tomorrow when i'm in work an let you know ;-)
Also if you search on youtube for "1.8 20v assembly" theres a guy that has done 4 or 5 videos of him rebuilding a 20v engine, which shows everything including fitting rings, rods, big ends and honing an measureing the tolerances an ring gaps. Its quite a handy couple of videos to watch ;-)
I'll try an find the link for you
Edit:
Link found
http://m.youtube.com/results?q=1.8 ....1ac.1.23.youtube-reduced..18.0.0.J72zMu-WsCw
Its the second one down, 6 videos in total but only 5 to do with the assembly
Thanks for that Cooper.
Yea i`ve been watching those videos for dinner for the last month lol.
My brother being a machinist and me being an engineer off shore we can fabricate just about any thing:)
I really need to get the Elsawin Cd`s
Yea i watched them a few times aswell before i started my rebuild lol. Yea the elsawin program is a massive help, i got mine when i had my A8 but didnt really use it that much, now that i got the S3 tho i'm using it all the time lol
yea i made the mistake of buying it off the net to download it and it so big(that's what she said),25GB its usually corrupt when you finished downloading it:(
The company has re linked me to the download link and i`ll try again when im home.
Deff gonna buy the CD of Flea bay as its on 5 quid more:)
847
959
798
624
