Balancing or Alignment, or Both?
Maq Jul 5, 2010
  1. Maq
    Maq Quattro_AvQ
    84
    Been a few weeks ivehad my car lowered and had my new 18's fitted. Was driving back from Goodwood and doing some speed on the empty roads, at about 70+ was getting a bit of vibration through the steering, didnt feel comfortable going over 80 as the car didnt feel too stable. Im sure i need wheel balancing, but dont know about Alignment. Thinking of getting balancing done, then checking if the problem persists before i have alignment done. Any Suggestions?.. Thanks
  2. rowdyboy
    rowdyboy Member
    804
    19
    The garage will normally check alignment for free and only charge if it needs adjusting, so you may aswell get it done
  3. Maq
    Maq Quattro_AvQ
    84
    I think every garage woud say you need to have it done!...
  4. rowdyboy
    rowdyboy Member
    804
    19
    Probably, what's your point??? Most garages, you can see the results. The other option is to fork out thousands on the equipment and do it yourself if you don't trust anyone else.
  5. jon1982
    jon1982 diesel dodger
    115
    i have this problem with my car at 70+ mph, alignment is spot on, had 2 new tyres on this year so fronts are balanced spot on, the rears have,nt had new tyres or been balanced since ive owned the car, could it be the rear tyre balancing causing the vibration because someone told me it could,nt be the rear tyres???? i hope they,re wrong otherwise whats causing it:uhm:
  6. s-line stu
    s-line stu Member
    182
    I have also had this problem before and it does seem to be down to balancing the wheels - even the backs as it was the backs that were out on mine and this was with new tyres so the garage can't have balanced them particularly well when they put the tyres on.
    The car seems to be quite particular about wheel balance and even if it's only slightly out I get very slight vibration but if it's spot on the vibration goes.
  7. solaris
    solaris Member
    416
    17
    The first step would be to get the following checked out:-
    Tyre pressure
    Wheel balancing
    Wheel alignment (including camber & castor)
  8. Maq
    Maq Quattro_AvQ
    84
    The problem has gone, jus needed tracking on the front 2 wheels...now it flys to 100 with ease and no hesitation!
