Balance shaft inspection/replacement plus parking sensors
tuffy Jan 2, 2013
  1. tuffy
    tuffy Member
    314
    13
    Afternoon all
    Booked my 06 170 tdi for the 14th of Jan for a balance shaft inspection/replacement plus parking distance sensors, the wife is a bit concerned about the length of the car so i thought it's a safer option to have them fitted.
    I will be quite interested to see what sort of condition the balance shaft hex is in! and how close it is to potential disaster.
    Will try to get some work in progress pictures of both the shaft and parking distance sensors, i've opted for cobra sensors and been talking to powermax in Ireland regarding the balance shaft
    Will try to keep this updated
  2. countax
    countax New Member
    17
    Tuffy,
    This would very useful info to those of us that would like to know what is involved in the inspection of the hex shaft. Can you pls advise what variant A4 you have, what cost is being quoted for the inspection and then assuming the shaft does need replacing, what the additional cost would be. I have looked into what is required to remove the sump on a Cabriolet to do my own inspection and it seems quite complex, with jigs to hold up the engine and specialist pins to hold the subframe in place to avoid losing wheel geometry. Will your garage be using this process or have they a more DIY friendly way to remove the sump?
    If the costs look reasonable then i might be interested in having them inspect my hex shaft if they are local to the Cotswolds.
    Looking forward to your pictures / updates on this thread.
    Nigel
  3. tuffy
    tuffy Member
    314
    13
    Hi Nigel. i may be wrong here but i cant see any reason why you'd need to support anything to remove only the sump, or there being any risk of damaging to wheel geometry
    Unless a cab is a completely different set up to a Avant (which mine is) its only a matter of removing the plastic undertray, and removing bolts that holds the sump in place
    There isn't any reason to loosen engine mounts or suspension parts just for a balance shaft/hex inspection/replacement
  4. Paul B7
    Paul B7 Active Member
    622
    34
    Mmmmmmmmmmmmmi i have a recollection that I once read the Audi technical Bulletin on this issues and the engine has to be supported from above and then the then the cross member underneath removed. I am also pretty sure the engine has to be moved to one side and then A/C unit slung out of the way ( which then needs a regas). This was to assist in the replacement of the chain driven unit on the BLB engine with the gear driven module.
    That said my engine was repaired by Audi themselves so there may be other ways ..........................
    Paul B7
  5. tuffy
    tuffy Member
    314
    13
    Thanks Paul. Would you need to do all that just to remove the sump??? I already have the gear driven unit so just want to inspect the balance/hex??
    I've been told its just sump off, balance shaft removed/inspected and replaced if needed??
    I stand corrected , Just spoken with my technican, seems we have to remove engine mounts and cross member to fully remove the sump
  6. Paul B7
    622
    34
    These ain't no Mk1/2 Escorts...................which is a pity really as with the old engines we didn't have these issues!
  7. tuffy
    tuffy Member
    314
    13
    You're not wrong there mate....My sierra 3 door cosworth had less issues, i know my balance shaft hasn't failed....yet, but prevention and all that!
  8. J0N35Y
    J0N35Y Member
    67
    You will need to support the engine from above as the sump will not drop down enough to remove it without removing the front crossmember. This supports the engine and also supports the suspension/anti roll bar. This is for a car with a longitudinal engine set up. It's not a 5 minute job trust me!
  9. ctd
    ctd Member
    106
    audi quoted me 5hrs just to inspect my chain drive, thats not fixing it of putting the bits back either but just to get to it
  10. tuffy
    tuffy Member
    314
    13
    Im now aware this isn't a job that can be completed during the adverts. Think it still makes sense to at least get it inspected to hopefully avoid major expense at any given time without warning.
  11. J0N35Y
    J0N35Y Member
    67
    If you can afford to have it done then it is well worth the money. Very wise decision!
  12. tuffy
    tuffy Member
    314
    13
    To be honest money i could do without spending, just think the potential alternative would be far more costly. I knew the issue existed before i bought the car so cant really moan about it.
    To get to the core of it, and i'm sure you'll all agree that this is a cost that no Audi owner should have to suffer. Audi should man up and recall all effected cars and stop pretending that this isn't a ongoing issue.
  13. J0N35Y
    J0N35Y Member
    67
    Here here........somehow I think this will never happen though 😩
  14. ctd
    ctd Member
    106
    when i rang Audi about my car just before Christmas i was passed on to Audi customer services, the woman told me in the most condecending voice," well what did you expect, the car has done 107,000 miles and is 7 years old after all!"
    with an attitude like that from customer services what chance has anyone got of any help from Audi, i cold feel my **** starting to boil at this point so put the phone down on her so she didn't make a very bad situation any worst
  15. J0N35Y
    J0N35Y Member
    67
    It's pretty vile that customer services from a "upper range" car manufacturer comes out with something like that. Surely they should be praising the product and if not surprised about an issue at least pretend! 😄 I'd have probably blown my top if that happened to me, fair play to you!
  16. apples24
    apples24 New Member
    mine was done the other month, just turned the shaft around as it sits further in on one side
  17. Macdoon
    Macdoon Well-Known Member Team Ibis TFSI Owners Group Gold Supporter Audi A4 S-line owners group
    2,023
    793
    Anymore info fella.... done by who, costs, time etc TIA
    Mac
  18. tuffy
    tuffy Member
    314
    13
  19. apples24
    apples24 New Member
    mine was coming apart anyway to put a new sump on but i would imagine a couple hours labour.
    he was originally gonna fit a allen key cut too length as there stronger but mine wasnt too worn after100000 miles, it wears at one side, as it sits in further on the other side he took the hex out and put it back in the other way round
  20. countax
    countax New Member
    17
    Tuffy,
    How did it go yesterday? Hopefully it was good news on the hex shaft wear front. Did you manage to get any photos of the work?
    Nigel
  21. tuffy
    tuffy Member
    314
    13
    Hi. Its work in progress, Only doing it in the evenings after work when my friends garage is closed, so far.... up on the ramps, undertray removed, oil drained, rear bumper removed for parking sensors, all four wheels removed for refurb.
    Wanted to get the bumper removed a sensors fitted first so the bodyshop can be spraying/refurbing while the balance shaft is being addressed.
    I will keep it updated
  22. Whopper
    Whopper Active Member
    278
    43
    Listening closely to this! :)
  23. tuffy
    tuffy Member
    314
    13
    Could be a very long work in progress!! Cut the parking sensors in earlier this afternoon but couldnt get bumper a wheels to bodyshop because of the snow!
    Hopefully will start the sump strip down later today or tomorrow. We've decided to replace the balance shaft whatever the condition of it. think its the sensible thing to do as the car will be stripped anyway
  24. adamss24
    adamss24 Well-Known Member
    4,584
    406
    You don't need to remove the subframe but the bumper needs to come off and the engine jacked up as far as it goes. The sump then can be taken off and will just about clear the subframe. Done it in the summer to a b7 audi a4 with the 2.0 Tdi 140Bhp engine. The car had already the gear type balancer shaft assembly (2009 model) but the hex drive was rounded off. The low oil pressure took 2 turbochargers off, the last one only 5k bought brand new from dealer ! Got the new hex drive for a fiver in local audi dealer + it needed an oil change and genuine white sump sealant ! Not a job to do on your own or in the cold !
    Funny thing is the car had 89k when the first turbo failed and upon questioning the dealer about the chain type oil pump drive they have assured me it has the gear type which is the better part which does not fail. Yeah, right ! The low oil pressure light came on at 98k !!!
  25. tuffy
    tuffy Member
    314
    13
    Thanks for that, we'll have a look into that method tomorrow, easier than dropping the subframe would you say??
    So the car in question had the chain driven oil pump plus replaced balance shaft and still failed??
  26. tuffy
    tuffy Member
    314
    13
    UPDATE!!!!
    Ok guys.....Due to the bad weather and just being too busy, we've only just removed the balance shaft tonight......and good job we did!!!!
    Case anyone doesn't know, it a 170 with 70k on the clock with full Audi service history, all i can say is glad we didn't leave the balance shaft much longer! Loads of play in the drive and the hex key was starting to round off
    Bit of a job to tell how many more miles it would of covered before failure but i'd be surprised if it would of seen 100k.
    I strongly urge anyone who hasn't, to get it checked!
    i'm now in the hands of powermax engineering, hoping for a quick turn a round on the uprated balance shaft. Will update again as soon as things progress
  27. Macdoon
    2,023
    793
    Thanks for the update Tuffy, keep us posted fella, turnaround time, price etc. I'm guessing there will be a lot of peeps watching this thread for the outcome.
  28. tuffy
    tuffy Member
    314
    13
    Here's a picture of the damaged hex. Sorry not very good but you can clearly see the shine on it caused by the wear!
    Dont know why the pic is so large either!!!
      File size:
      125 KB
      171
  29. Darren198712
    Darren198712 Member
    194
    14
    wow. great update.
    can't really see clearly but can kind of make it out
  30. tuffy
    tuffy Member
    314
    13
    I will, i can give a rough indication on price for the uprated balance shaft. £295+vat on an exchange basis.
  31. Macdoon
    2,023
    793
    What engine code is yours Tuffy.
  32. tuffy
    tuffy Member
    314
    13
    BRD mate
  33. Macdoon
    2,023
    793
    Mine too, so are you taking the car to be done or dending the bits off for replacement
  34. Darren198712
    Darren198712 Member
    194
    14
    mines a BRD engine too :'-(
  35. tuffy
    tuffy Member
    314
    13
    You need to have the balance shaft removed mate then send it off to powermax for them to uprate, they may have them on the shelf so one to two day turn a round, if not they uprate yours then ship back. Either way you send them yours as its on an exchange basis.
    Hope that helps mate
  36. Macdoon
    2,023
    793
    Cheers fella, can't wait to hear it all goes
  37. Darren198712
    Darren198712 Member
    194
    14
    Tuffy and Macdoon have you ever thought of converting the oil pump back to a 1.9 ?
  38. Steve220
    Steve220 Member
    234
    15
    That WAS lucky! What is the length of the hex shaft? (as accurate as possible if you would be so kind)
  39. Macdoon
    2,023
    793
    Tell us more Darren
  40. matthew999
    matthew999 Member
    146
    Hi Tuffy,
    Good to here your pro active approach, that wear looked pretty bad. I think im going to do something similar in the summer. Let us know how fast the turn around is at powermax. Also are you changing anything else while you have the balancer module out, oil pump or crank gear? Also how long did it take the garage to get to the point of inspection.
    cheers
    Matt
