Baffled sump kit/ DIY Baffled sump
Rob_B May 22, 2011
  1. Rob_B
    Rob_B Member
    192
    hi chaps,
    after my recent misfortunes im looking to baffle my sump and was just wondering if anyone knows of a reasonable priced kit or is there a DIY one that someone has done?
    regards
    rob
  2. Andy123
    Andy123 Member
    260
  3. superkarl
    superkarl MAN OF STEEL
    9,324
    2,329
    I think the tt shop do them. Not cheap though if memory serves me right. If you know anyone who is confident at welding alluminium then give it a go
  4. Rob_B
    Rob_B Member
    192
    yes i know some very good ally welders, jut wanted to see if someone knows of a thread on this forum or any other forum that will help with with designing it?
  5. <tuffty/>
    20,803
    3,664
  6. MUSH
    MUSH MUSH Developments Ltd.
    713
    12
    Whats been your recent misfortune bud? Sump related?
  7. Rob_B
    Rob_B Member
    192
    track day, oil starvation, screwed bottom end :(
  8. sportstractor
    sportstractor Chugger
    2,709
    35
    Baffled sump? Track use I take it? I doubt you will find any designs but would be easy to design providing you get clearances correct. Not what your after, but I was reading into those accusumps a while back, ideal bit of kit, especially if your expecting loss of oil pressure. Also reduces wear on startup
  9. Rob_B
    Rob_B Member
    192
    yeah i was looking at them too...if i went for the accusump im guessing i wouldnt need a baffled sump? and yes its in regards track use
  10. Prawn
    11,354
    3,191
    EEK!
    This scares me a little! Not had a problem YET in mine, but most definitely looking to get a baffled sump soon!
    What were the signs before it went Rob? or did it just suddenly start knocking?
  11. <tuffty/>
    20,803
    3,664
    Bill runs a Backdraught sump, sticky tyres, big brakes and a light car will be the issue for you Nick... if I was doing serious tack day stuff like you I would be considering a baffled sump tbh... the Backdraught ones are based on the SEAT Sport sumps done for the factory race cars...
  12. badger5
    9,316
    1,888
    the pictured pro-alloy one makes me nervous of the rubber baffles only being retained by their 2 little "pips"
    I have known 2 sumps of this "ilk" detach a rubber baffle, which unluckily for the owners got sucked into the oil pickup pipe, causeing loss of oil pressure and.... well, you can imagine.
    SEAT Sport sumps, of which there are copies of, have a large full width rubber baffle which does not come off. This is the type I run and use, and they are now available thru backdraft motorsport
  13. Rob_B
    Rob_B Member
    192
    oil pressure light came on and soon after that the car died, very very sudden really i was extremely shocked and rather annoyed as you can imagine
  14. Rob_B
    Rob_B Member
    192
    can anyone tell me the thickness of the ally plates in the baffled sump?
  15. badger5
    9,316
    1,888
    1mm ish.. pretty thin.. Too thin to easily weld onto the much thicker cast sump
  16. Rob_B
    Rob_B Member
    192
    thats cool, i wont be welding it ;) a good friend of mine runs a precision engineering company, so one of this decent ally welders are gonna do the job for me hopefully
