Badly fitted RNS-E unit - any tips for a better fit? (images included)
Agent_Trig Apr 11, 2011
  1. Agent_Trig
    Agent_Trig Member
    552
    I will be replacing my old RNS-E unit for the newer MK2 when it arrives later this week :)
    Something I have noticed with the one currently installed is how bad the fit is, which you can see in the photos below. There is a gap on the right hand side, its pushed up tight on the left, a large gap along the top and the bottom left hand corner is sticking out.
    Before I start with the swap, does anyone have any tips on how to avoid this or can you let me know how this could of happened?
  2. RU55SSO
    RU55SSO Member
    792
    24
    Try re a ranging the cables making sure you get maximum clearance. Check the unit itself for any clip damage
  3. HIGGINS
    HIGGINS Member
    528
    15
    When you remove it and fit the new one make sure each corner 'clicks' in properly
  4. NHN
    29,280
    1,692
    Was the rns an original factory fit or did you do a double din conversion to fit?
  5. Agent_Trig
    Agent_Trig Member
    552
    I never fitted this unit but I will be fitting the new one when it arrives.
    The one that's currently installed (badly), was not factory fitted as the car originally came with a Symphony II according to the service book.
  6. RU55SSO
    RU55SSO Member
    792
    24
    It may be possible the cage is not seated correctly
  7. Agent_Trig
    Agent_Trig Member
    552
    I was wondering this because where the bottom left hand corner sticks out, it is solid. I cant push it in or anything and there is no play in it at all.
  8. Agent_Trig
    Agent_Trig Member
    552
    Actually, while I've got the pictures loaded up, could anyone tell me if I have the right newest version of the hazard switch plate installed? I have seen some A3's with a slightly different plate where the buttons are more flush whereas mine are more rounded.
  9. NHN
    29,280
    1,692
    Remove the button trim then see if it sits properly, I was getting at if the cage was fitted wrongly.
  10. Agent_Trig
    Agent_Trig Member
    552
    How do I remove the button trim?
  11. sub39h
    sub39h Active Member
    2,502
    if he had Symphony II from the factory the double DIN cage would have been factory fit also so that's unlikely to be the problem. i reckon it's just not been pushed in enough - maybe because there's a cable in the way at the back.
