Badger 5 80mm Pipe with air box query.
rhinopower
Member
Hi Guys
Got stuck in fitting my TIP today, i struggled a bit at first and Bill is kindly sending me out an adaptor to extend one of my hoses, but i can't seem to get it to sit right on the air box without 'collapsing' the hose a bit. The guide suggests trimming a bit off the hose but i don't think that will fix my problem, it is as if my air box is too high? I'm not sure if maybe part of the maf housing itself wants trimming, or wether because its an import, my car has a slightly different air box.
I've attached a picture, hopefully someone can tell me what i've done wrong :)
Hi, having had one on my previous car the tip seemed to "cobra neck" on the bend. I took it to Mr badger for a health check and asked about that.
A little bit of cobra necking okay as long as its not a major squash on the bend.
cobra necking= flattening on bend
There is certainly some cobra necking, I won't worry if its ok as it is, I'm just puzzled that i'm having the opposite problem to what i should do. I've got a brand new piper cross panel filter, i'm not a fan on cone filters, particularly when i like to keep an OEM looking engine bay.
I too would stick with a panel filter if it went for one of these TIPs. Was you previous TIP the standard one? Have you done any logging? Does it feel any different/better?
I should do some logging, standard pipe on there before. Which blocks do I need to log on vagcom.
Il try taking 10mm off the maf end of the silicon hose and see how that improves things
I hate you all! Lol, What cone filter and head shield should i be looking at? I've spent nearly £2k since i bought the car a month ago including clutch and dmf, good job i only paid £1500 for the car.
I originally wanted to keep the standard airbox myself with the B5 TIP, but once I saw the gains of a cone filter, it was a no brainer really.
What are the gains from your experience of having a cone filter?
I had the B5 TIP and cone fitted at the same time, and had before and after RR aswell, think I gained 15bhp? off the top of my head, which is an amazing for an induction kit. The gains are through the rev range too, just feels livelier on the road.
One is not disconnected from the other I suspect.
purchase price vs expenditure thereafter
you are in a big club.... and going down the same path as others
Yeah my s3 felt restricted when I first bought it standard, fitted a b5 tip myself plus cone filter as it is reasonably cheap mod, and the car came alive, was going to work one morning and my work colleague was behind me in his Impreza wrx standard, a stretch of Tarmac opened up about 2 miles long, no traffic, and he couldn't get past me, was chuffed with that, or maybe he can't drive ha!
Bought filter this morning, and this evening i am picking up a non resonated miltek for a mere £280!
Reactions: jojo
I've been looking for a second hand miltek for quite some time, never seem to find one!
Bought and fitted the cone filter instead. It's still got a slight kink, needs tweaking and data logging :)
Sunday 12 October 2014 12:07:26:60231 VCDS Version: Release 11.11.0 Data version: 20111111
8L0 906 018 N 1.8L R4/5VT 0002
Group A: '002 Group B: '003 Group C: '118
RPM Load Inj. On Time Mass Flow RPM Mass Flow Load Ign. Timing RPM Temperature Load Absolute Pres.
TIME TIME TIME
Marker STAMP /min % ms g/s STAMP /min g/s % °BTDC STAMP /min °C % mbar
1 208.82 1520 63.2 6.97 21.06 209.22 1600 25.92 72.9 17.3 209.6 1680 21 92.9 1100
209.89 1760 94 9.43 32.69 210.19 1800 35.64 81.6 14.3 210.49 1880 20 92.9 1200
210.79 1960 106 10.66 40.47 211.09 2040 45.03 88.2 12.8 211.39 2120 20 92.9 1330
211.7 2200 123.3 12.3 54.39 211.99 2320 59.83 93.7 12.8 212.29 2400 19 65.1 1520
212.6 2520 153.4 15.58 76 212.89 2680 80.17 98 10.5 213.2 2800 19 57.6 1690
213.5 2920 157.9 15.58 88.97 213.8 3040 91.14 100 12 214.19 3280 19 70.2 1900
214.49 3400 191.7 18.86 130.5 214.89 3640 141.17 100 10.5 215.18 3800 20 77.6 2280
215.49 4000 191.7 20.91 160.94 215.79 4200 167.5 100 10.5 216.09 4400 21 78.8 2330
216.39 4560 191.7 21.73 182.56 216.69 4720 187.44 100 8.3 216.99 4880 22 78.8 2290
217.29 5040 191.7 20.91 198.97 217.59 5200 203.97 100 12 217.9 5360 24 81.2 2250
218.19 5480 128.6 11.48 111.86 218.49 5360 0 3.1 10.5 218.79 4960 21 0 1250
219.09 4600 2.3 1.23 7.53 219.39 4280 7.42 3.1 9.8 219.69 4000 22 0 1070
219.99 3720 9.8 0 6.86 220.28 3440 6.56 2.7 9.8 220.7 3120 23 0 1040
2 220.98 2920 6.8 0 3.86 221.28 2760 4.08 2 9.8 1421.61 2680 23 0 1030
1421.94 2520 7.5 0 3.64 1422.25 2440 3.5 2 9.8 1422.55 2360 24 0 1030
1422.84 2280 8.3 0 3.86 1423.14 2200 3.44 2 9.8 1423.44 2120 24 0 1030
1423.75 2080 8.3 0 3.14 1424.05 1960 3.61 2 7.5 1424.35 1880 24 0 1020
1424.64 1840 8.3 0 2.89 1424.94 1760 3.03 1.6 -1.5 1425.24 1720 24 0 1020
Hows this look log wise now with the Tip all fitted etc? I think the silicon might need redoing on the turbo join to the billet adaptor. I dont know if i need to upload the log differently?
you hit 204g/s at one stage which is amazing. Using a rough calc that would estimate your bhp to be around 255 which is unreal.. What other mods does your car have? Been mapped?
Reactions: rhinopower
Stage 1 remap from CCC-tech, badger 5 tip and induction kit. Forge recirc valve with 1 spring up from standard, milltek exhaust. :)
13
881
746
834
