Bad condensation
AudiLeon Dec 11, 2012
  1. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,250
    192
    Firstly. The carpets are dry. No sign of water ingress.
    But when I finish work, the wind screen is drenched. Today it was frozen on the inside. URGH!!
    This is bad news for me, as I'm an on call fire fighter. I need my car quickly.
    Plenum chamber is clear and the plugs are gone.
    Pollen filter is brand new.
  2. Jp-tqs
    Jp-tqs Member
    183
    Sounds annoying mate. Ok, you've ruled out the obvious so now id check door seals. When you open the doors (when the problem is apparent) check for moisture ingress on the seals. Eg, no moisture on top or inside the seals? I sometimes think the vents on the dash under the windscreen cause this??!! Try a towel or similar over the vents after shut down? Just throwing ideas at you mate, no definate answer though, sorry!
  3. munchkincoupe
    munchkincoupe Member
    948
    19
    Are your dash vent motors all working?
    Do you have aircon? is it working well? how long since regas?
    Condensation on any other windows or just the front screen?
    Sunroof?
  4. AudiLeon
    2,250
    192
    Front and rear screen. Front is much worse.
    Aircon was charged 2 years ago and gives 9bar when running on vcds. Still gives out cold air in summer.
    All motors have recently been stripped down, reworked and greased. All work smoothly.
    No sunroof. No signs of water in the actual car. It's odd.
    It's not all the time, just with a hard frost on the screen.
  5. vr6gordy
    vr6gordy Well-Known Member
    2,826
    191
    get some anti fog ..this will stop it happening
  6. Artimus
    Artimus Shortback
    2,017
    487
    All that will do is make it clear & wet, it won't cure the underlying issue!
    Have you had the windscreen seal checked?
  7. Mike B
    Mike B Well-Known Member
    1,128
    40
    Had this on my previous B6 and assumed it was normal in cold weather but my present car has much less.The only thing I never checked was the aircon drain
  8. AudiLeon
    2,250
    192
    It had a new screen in about 2 years ago. But if it was aircon drain blockage or window seal. I'd expect wet carpet or some sign of water?
  9. Artimus
    Artimus Shortback
    2,017
    487
    If the seal is leaking\perished at the bottom, under the wiper trim, you'd probably just get enough moisture come through in wet weather to mist the glass.
    It cant hurt to get the trim off and get in there with a sealant gun to be on the safe side.
  10. AudiLeon
    2,250
    192
    So you reckon reseal along the base of the wind screen? I have some windscreen sealant... hmmm
  11. Artimus
    Artimus Shortback
    2,017
    487
    that's the job half done then. lol
  12. pink.teg
    pink.teg Member
    170
    Hi m8
    im sure another , has written about this coz I had that 3/4 days ago and changed the pollin filter
    2 min jobs and its all good now .. Have ago
    best of luck
    alan
  13. Mike.M
    Mike.M Well-Known Member
    2,510
    170
    He mentioned the pollen/cabin filter is brand new unless it has not got a proper seal when put back together.
  14. AudiLeon
    2,250
    192
    Is it possible for the filter not to seal? It doesn't seem like it would seal tbh.
    On a good note, it passed it's MOT today.
  15. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    You do have to be careful to get the filter in place and the seal/clips back in place.
  16. AudiLeon
    2,250
    192
    It never looks like it seals though. Just sits in with a cover?
  17. gen.heinz guderian
    1,346
    126
    The cover has to locate at the back and lock in at the front to seal properly.
  18. AudiLeon
    2,250
    192
    I'll double check that tomorrow. Cheers.
