Bad Battery? or something else
ENZO Nov 12, 2013
  1. ENZO
    ENZO Member
    166
    Hi,
    my car failed to start yesterday and had to be jumped, i didnt leave any lights on etc...Drove home fine
    It started this morning but struggled, pretty sure the alternator is fine. Maybe just a weak battery?
    Gonna get it checked when i have time, do anywhere do free checks?
    and if i get a new battery is it a straight swap or does anything need resetting?
    car: Audi A3 2.0 TFSI Quattro SLine 2007
    appreciate it if anyone can answer these, Thanks :)
  2. Jonathaan
    Jonathaan Quattro
    720
    120
    43
    I had same problems a few months ago, replaced the battery and it cured it.
    Nope can be a straight swop - i payed around £35 for a Varta battery and it was just a case of removing old, and putting new in.
    Time and date will need resetting, and on first start i think the ESP will show fault (does on mine) then it clears.
    Jonny.
  3. ENZO
    ENZO Member
    166
    thanks for the reply
    did you buy the battery online?
  4. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    Prob on original factory battery. Which in that case it'll be time for renewal.
  5. SPARTAN91
    SPARTAN91 RED FIVE STANDING BY Regional Rep Team Silver Audi A3 TDi
    484
    167
    43
    I replaced my 5 year old battery the other week as I had the amber symbol come on in the DIS saying low charge.The light hasn't gone out with a new battery so it went into my local dealer yesterday turns out all is OK with that side of things and it's all down to a fault with the instrument cluster so only fix for that is a new one.
  6. NHN
    29,532
    1,769
    Varta Ultra Silver Dynamic, best battery for the 8P & not expensive either :)
    Search forum for this, as I've detailed part numbers various times.
    maikysupra likes this.
  7. JJ.Foulds
    JJ.Foulds Well-Known Member
    1,263
    176
    got mine for like £70 delivered, and its been great. and such an easy change, and it was more powerful than the battery i had it before!
  8. ENZO
    ENZO Member
    166
    would have gone for that but too late now, already ordered
    this is decent enough i think
    cost £57
  9. JJ.Foulds
    1,263
    176
    'the S3 is perfect for older and more basic vehicles with fewer electrical consumer devices'
    Erm, arnt AUDI EVERYTHING is electrical? lol, i was under the impression they are heavy juicers.
  10. JJ.Foulds
    1,263
    176
    THE BOSCH
    • Amp Hours: (Ah): 53Ah
    • Cold Cranking Amp: (CCA): 470cca
    THE VARTA
    [TABLE="class: left, width: 357"]
    [TR]
    [TD="class: evenrow label bold, bgcolor: #D5D6D8"]Battery Capacity [Ah]:[/TD]
    [TD][/TD]
    [TD="class: evenrow data, bgcolor: #D5D6D8"]77[/TD]
    [/TR]
    [TR]
    [TD="class: oddrow label bold, bgcolor: #E6E6E7"]Cold Cranking Amps (CCA), EN [A]:[/TD]
    [TD][/TD]
    [TD="class: oddrow data, bgcolor: #E6E6E7"]780[/TD]
    [/TR]
    [/TABLE]
    The VARTA is significantly better for only £13 more, if i was you id be asking for a change of order.
  11. ENZO
    ENZO Member
    166
  12. geforce189
    geforce189 Member
    53
    I have the same car with the same age. What's the easiest/best way of checking if it's on it's way out before it's too late?
  13. coxy8329
    coxy8329 Member
    167
    19
    Yes that should fit, fitted one in my A3 last week. A much better battery that the original. :rock:
    ENZO likes this.
  14. JJ.Foulds
    1,263
    176
    A local garage shud do a free battery check, takes most part of 30 seconds and will give a voltage readout. should be around 14v I THINK.
    geforce189 likes this.
  15. Jonathaan
    Jonathaan Quattro
    720
    120
    43
    Bought it from a local car shop near me, looks like youv sorted this problem owt now tho? Be sure to update us when you come to fitting the new one (y)
