back window washer
dantdi Mar 13, 2008
  1. dantdi
    dantdi ...
    521
    Any one had problems wit back window washer? Not had chance to look at mine yet. can hear the motor running but thats it. Any one took there tail gate inside panel off? if so how easy ?
    Dan
  2. S3 chj
    S3 chj Member
    306
  3. abdus
    abdus Top Gear VCDS Map User
    1,827
    did you check in the rear quarter panel inner arch for fluid loss? if it is there, then it might be the pipe got disconnected under the sub unit...
    I had the same problem...check this pic:
    this might also help :)
  4. jonS3
    jonS3 Member
    719
    haha, isn't that my car?
  5. freddie
    freddie New Member
    19
    I am having the same problem myself, i took apart the boot and all i could find was what looked like a pump (wrapped in a foam type block) it had a pipe in and a pie out? is this a secondary pump? i had no joy anyway. unless that is a waterpump and has gone faulty. i have checked the connection to the wiper motor and that is fine. it is wrecking my head:keule:
