back speakers wont work with my sony stereo why?
matty18T Aug 25, 2012
  1. matty18T
    matty18T Member
    37
    hi there when i brought my a4 its a 99v a4 1.8 it had a ripspeed tv dvd thing in it and the back speakers wouldnt work so i put my sony xplod in and the same thing ?? do u need a special lead or anything ?or i am i gonna have to run new wires? hope anyone can help
  2. aragorn
    18,579
    868
    Theres a couple of options to fix it.
    As standard the front speakers are driven by the head unit, and the rear speakers are powered by a small amplifier in the rear of the car. If its a saloon the rear amplifier is mounted to the underside of one of the rear speakers, if its an avant its mounted in the subwoofer assembly behind the left hand boot trim panel.
    The simplest way to fix it is to buy a PC9-404 lead, and plug it in. This will use the pre-outs from your Sony head unit, and feed them to the standard Audi amplifier. Easy fix and minimal effort, but the sound quality can sometimes be a bit crappy as the rear amp often isnt as good as the amp inside the head unit driving the front speakers.
    Alternatively, you can rewire the rear speakers into the head unit, but this is only really an option on saloon models, as on a avant doing that would lose you the factory subwoofer and it would probably sound a bit rubbish.
    With mine i went the extreme way and installed a proper 4 channel amp to drive the door speakers, a 12" sub and an amp to drive that, and just ran preouts from the head unit. Its a more involved method and costs a lot more, but it also sounds a LOT better!
  3. matty18T
    matty18T Member
    37
    cheers for that im gonna see if I can get one today .also are the amps on the back speakers big cause mine just look like they have boxes round them which is part of the trim
  4. Royh1179
    Royh1179 Member
    70
    no they aint big at all matty and you may find only 1 speaker has them on as the lil amp i had on mine feads both speakers personally and for best performance id take the above advice and do your own full re-wire thats what ive done :)
    get a good 4 channel amp and some good components and a nice sub n amp package to giv you the nice lows , personally ive gone full rockford fosgate :) but choice is yours you will find u will need an arial booster also
  5. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya saloon TDi
    15,164
    1,123
    Not true.
    I rewired my stereo and ran the rear speakers in to the stereo and kept the rear sub and rear speakers.
    Used the rear right/left + from the HU in to the AMP cables and it worked fine.
