Back speakers keep coming on and off
boson Jun 2, 2009
  1. boson
    boson New Member
    26
    could this just be a loose connection?
  2. AndyMac
    9,832
    45
    If it's the non Bose system, then does the sub cut out as well? Is the system completely stock or are you running an aftermarket HU?
  3. Cockney Boy
    Cockney Boy Member
    483
    If you have VAG-COM, then it may show a fault code?
  4. boson
    boson New Member
    26
    it's all bose and original
    could it be a loose connection?
  5. AndyMac
    9,832
    45
    On the Bose system I'm amazed you can even tell if the rears are on or off, the rears are unbelievably fisher price.
    Is it dependent on anything i.e. bumps in the road or heat?
    Bumps would indicate loose connection but it's more likely a dry solder joint on the amp as the Bose amps are very prone to this. When they cut out, if you jack the volume up do they come back on?
