Back light cluster removal
Block 405 Aug 16, 2009
  1. Block 405
    Block 405 Member
    64
    Hi,
    I noticed the centre part of the little nut that hold the rear light cluster in place on my avant has been worn and rounded off. What size socket can I use to get it loose to remove the light cluster.
  2. BahnStormer77
    BahnStormer77 BahnStormer
    2,771
    58
    should be able to fit a phillips (cross-head) screw driver in there too....
  3. Block 405
    Block 405 Member
    64
    cheers, its seems pretty rounded though, nothing seems to be getting it turning .....
  4. 1wheelonly
    1wheelonly cabriolet VCDS Map User
    2,385
    111
    long nose mole grips
  5. Block 405
    Block 405 Member
    64
    cheers will try that
