Back in an S3....with a nice surprise!
-Ju- May 17, 2014
  1. -Ju-
    -Ju- Well-Known Member Team Panther VCDS Map User Audi S3
    2,356
    472
    I sold my 08 3 door S3 back in 2012 and last week I bought a 59 plate S3 Sportback S-tronic.
    I fitted my BBS CKII's the next day and this morning I fitted some H&R springs to sort the ride height.
    While the car was jacked up i found it had a full milltek system inc sports cat, no wonder it sounded different to my old S3
    Now I was planning on a remap at some point but something tells me why would you fit a sports cat and not remap it. The car doesn't feel remap quick like my old APR'd S3 was so it may have been turned off or removed by the dealer. So without going back to the original owner how can I tell?
    Next on the list is cruise, then roof rails and then possibly a retrofit of the auto lights/wipers (yeah I know its a biggie)
    Maybe the car is known on the forum, does the plate ring a bell?
    voorhees and MattS5 like this.
  2. grchmason
    grchmason Active Member
    764
    239
    43
    How did you find the fronts springs fella???? I keep getting let down so looking at fitting my eibachs myself!!!!!
  3. grchmason
    764
    239
    43
    Any tips lol!!!!
  4. -Ju-
    2,356
    472
    They are a doddle m8, I have done it loads of times now though.
    You need some spline bits for the link rod ball joints and the main strut bolt and a hub spreader. I did all 4 in 1 1/2hrs
  5. -Ju-
    2,356
    472
    Also to strip the strut you need a 7 mm Allen key and either a spark plug socket that you can get a spanner on or a swan neck spanner. No spring compressors needed.
  6. too hot
    too hot Active Member
    98
    25
    What's wrong with going back and asking the previous keeper ?????
  7. -Ju-
    2,356
    472
    As long as I can get in touch with the previous keeper then no problem at all.
    I just want to explore other avenues.
  8. Dave-S3
    Dave-S3 Active Member
    653
    124
    43
    You don't need to remap if you fit an exhaust system, its just recommended to release the power, has it got an intake fitted too? If so its more likely its been remapped to stage 2... Ask the dealer? Just say I've been told the cars remapped, can you check for me?
  9. -Ju-
    2,356
    472
    No intake fitted and yes I understand that a remap is not required but would you fit a full system and then not remap it?
  10. Dave-S3
    653
    124
    43
    Hmmm, possibly It might have been done via a bluefin though and the map was removed by the previous owner before it was traded it in, id get in touch with the owner to find out!
  11. nluk100
    nluk100 Well-Known Member
    1,035
    192
    Get someone local to you with vcds to log boost and airflow to see if it's still running a map of some kind.
  12. -Ju-
    2,356
    472
    I have vcds, any idea what a standard map flows?
  13. Scoot Yo
    Scoot Yo Member
    214
    Wish mine came with that! I assume being a circa 20k car he didn't buy it of someone's driveway and bought it from a dealer, hence not having the previous owners details.
  14. mjr901
    mjr901 Guest
    I remember when you bought the R36 and left the 8P world, how come the change back?
    The noise those things make with the good exhaust is epic!
  15. Dan-Jnr
    Dan-Jnr Well-Known Member
    1,234
    386
    That's a nice little extra to find.
    Standard air flow for an S3 is 205-210g/s if its remapped then it should be 225+g/s
    -Ju- likes this.
  16. -Ju-
    2,356
    472
    Correct I bought the car from Wakefield Audi. Spoke to the salesman and he is going to ask the previous owner but he thinks it is unlikely he put it on and tbh judging by the crud on the tailpipe, it's been on a while.
    The R36 was beautiful but the wife thought it was like driving a barge and tbh the S3 sportback with Stronic was just too expensive for me at the time, but it was the car I've always wanted. A perfect blend between practicality and performance!
    The number of people that would just stop and stare at the R36 though was unbelievable!
  17. -Ju-
    2,356
    472
    Thanks for that, I'll report back!
  18. Johnny Bravo
    Johnny Bravo 6+1 Gears Audi A3
    898
    70
    That indeed is a nice surprise!
  19. -Ju-
    2,356
    472
    Well I logged it this evening and it peaked at 222 g/s consistently, I guess if standard is up to 210 g/s then the extra 12 could well be down to the exhaust & cat?
    S3_Mat likes this.
  20. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,218
    2,033
  21. -Ju-
    2,356
    472
    Cheers m8, sure does feel good:rockwoot:
  22. nluk100
    1,035
    192
    Yeah, a sports cat will add a few hp for sure. My stage 1 with pre-cat removed was running 235 g/s. Having had a mapped S3 before you should know what a map feels like. It may of been flashed back to stock by the dealer during a routine service check (was it a main dealer?). Previous owner should be on the V5 too?
  23. -Ju-
    2,356
    472
    Not got the V5 back yet but my guess is it was the owner before that had it fitted.
    My plan is to go APR when I'm ready as I like the maps
    I also like the ability to use the cruise switch and the anti-theft.
  24. wrecksigge
    wrecksigge Member
    40
    God thats a lovely interior! :wub:
    -Ju- likes this.
  25. grchmason
    764
    239
    43
    Perfect getting ready for tomorrow can you remember the size of the spanner swan neck I will need with the 7mm allen key please?
    21mm ?
  26. -Ju-
    2,356
    472
    Yes 21mm
    Plus you'll need
    Drop link - 18mm spanner and M6 spline bit
    Hub bolt - 18mm spanner and M14 spline bit
    A hub spreader or some means of opening the joint a little
    You can ease up the scuttle panel just enough to get in to the 3x13mm bolts without taking the wipers off
    The backs are 1 bolt!
  27. Mike X
    Mike X Member
    151
    13
    +1 on the interior , well jel :drool:
    -Ju- likes this.
  28. grchmason
    764
    239
    43
    Thanks mate
    Thats a great help sorting tools out now Spline i'm finding hard lol
  29. -Ju-
    2,356
    472
    Halfrauds!
  30. mechanic69
    mechanic69 Well-Known Member VCDS Map User Gold Supporter Audi S3 DSG
    1,468
    553
  31. -Ju-
    2,356
    472
  32. mechanic69
    1,468
    553
    Nice one, when I got mine halfords only went up to 12mm, nice to know they go larger now.
    For the strut I use a 21mm ring spanner and the 7mm hex that comes with the Halfords pro socket set.
