B8 Steering wheel in a B7
Wrath Dec 1, 2010
  1. Wrath
    Wrath Well-Known Member
    1,196
    42
    Wanted to upgrade my 3-spoke MFSW for one with the silver multi-function buttons and an S-Line badge (didn't want an S4 steering wheel), sadly the B7 range never came with them so I thought I'd buy a refurb off an ebay seller and swap out the buttons as I bought the silver buttons separately.
    After archiemac posted to say he had fitted a B8 S4 wheel, I thought I'd take the plunge and bought a bargain B8 S-Line wheel off ebay.
    Fitted it last night, in the freezing snow and it works beautifully and really sets off the interior.
    So, those people with a 2005-2007 B7 will probably have a steering wheel part number of 8P0 419 091. You can replace this with an 8K0 419 091. It's possible that the 2007-2008 wheels, I think are 8E0 419 091 will probably work as well.
    Guess I'll have to flog my silver buttons on ebay (they were pricey!).
    Here's a pic:
    ruairi83 likes this.
  2. icenutter
    icenutter Member
    596
    A nice touch. I like!
  3. Irish EK
    Irish EK Member
    92
    that looks really good wrath! the silver really goes well with your interior!
    apart from the steering wheel itself, did you need anything else?! i currently have a 05 A4 with a 3 spoke steering wheel and have been looking into changing it to a MFSW. what else would i need to do this conversion?!
  4. Wrath
    1,196
    42
    Changing from a MFSW to a B8 MFSW needs no extra's but to go from a non-MFSW to a MFSW requires a few components. There are various threads on here about what you need and you'll need the correct part numbers. Keep an eye out on ebay.de for them.
    You'll need a new steering wheel control module, slip ring, airbag harness and steering wheel.
  5. AudiSport
    AudiSport Member
    511
    LIKE IT WRATH!
    What kind of job was it to fit? I have a four spoke SE MFST steering wheel currently fitted to my A4 and I'm looking to change it for a nice S-Line three spoke wheel.. However it is proving expensive due to the fact the steering wheels being sold with Airbags are about £450@!
    Are you going to sell your old wheel - however I guess you have re-used your airbag?
  6. Wrath
    1,196
    42
    Cheers mate. Yep, I've kept the airbag as they are pricey and there was no need to swap it over.
    Have in mind that you might be able to sell your current airbag so you might get money back on it.
    Swapping it over was easy, I'm a dab-hand at taking wheel's off now ;)
  7. Blanchie
    Blanchie New Member
    Tell me, was your old SW a 'multifunction' type or did you upgrade that function as well?
  8. Wrath
    1,196
    42
    I originally had a non-MFSW. Got all the bits and installed a MFSW and cruise. Then swapped the MFSW for this one.
  9. V6 Quatt
    V6 Quatt Well-Known Member
    1,248
    441
    Will I be able to fit the 8E0 419 091AH MFSW to my existing 4F0971 589A Airbag??
  10. AudiB7Jay
    AudiB7Jay Active Member TFSI Owners Group Team Sepang Audi S1 Audi A4 saloon S-line owners group Team Aruba Blue TDi Manual
    480
    34
    I got this wheel as standard in my b7 just without the sline badge
  11. wyliss
    wyliss Member
    286
    Nice mod Wrath. I've previously retrofitted a MFSWand cruise to my car but the SW didnt have the badge etc. Is it basically a straight swap then? I hope so !
  12. hades-
    9,482
    646
    where do you dig these up from 2010
  13. wyliss
    wyliss Member
    286
    Google is your friend:unsure:
  14. Wrath
    1,196
    42
    Wow blast from the past! The wheel is a straight swap. The B7 version doesn't have silver trim and doesn't have an S-Line badge.
  15. hades-
    9,482
    646
    mines got the s-line badge but no silver trim
  16. V6 Quatt
    1,248
    441
  17. wyliss
    wyliss Member
    286
    There's one on the bay but they want £100 for it. Worth it?
    Also whats the procedure for the change. I realise airbag off job.
    TIA
  18. hades-
    9,482
    646
    stright swap if you have MFSW.
    make sure its not from the A3 tho
  19. V6 Quatt
    1,248
    441
    Bez, do you know what ~Audi steering wheel this part numbers from 8e0 419 091
  20. wyliss
    wyliss Member
    286
    What's the difference with the A3 one?
    I've seen a recent advert saying this wheel will fit A3/4 etc????
  21. Wrath
    1,196
    42
    The A3 one is shallower and the airbag screws are in a slightly different place.
  22. Lion Heart
    Lion Heart Member
    118
    Hi guys
    To clarify one point: the original poster has a manual car...
    Is it also a straight swap for those with Tiptronic paddle shift (S4 etc)?
  23. EddyP
    EddyP Member
    96
    19
    I was sure I read somewhere about there being an issue with single/dual stage airbags? or is that putting a B8 wheel onto a B6?
  24. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    B6 has single stage airbags,both B7 and B8 have dual stage airbags.
  25. V6 Quatt
    1,248
    441
    Yes as I have upgraded
  26. DerClown
    DerClown Member
    56
    Hi guys,
    I just purchased Audi B7 Cabriolet. It has RNS-E but no MFSW.
    My steering wheel is 3 spoke B7 stock. I wonder if I get same steering as in picture above from B8 s-line will my airbag fit ?
    So I could buy it cheaper from damaged car.
    Thanks for response !
  27. V6 Quatt
    1,248
    441
    It will depend if you have a dual or single stage airbag. You will need to check as cab wheels are different from saloons in fitments
  28. ruairi83
    ruairi83 Well-Known Member Team Sepang quattro Audi A4 Black Edition
    1,707
    557
    Ive have a b8 sline wheel for sale in classifieds if anyone needs one.
  29. Just Rob.
    Just Rob. Moderator Staff Member Moderator Team Daytona TFSI Owners Group Team V8 VCDS Map User Gold Supporter Team Brilliant Black Audi RS4 quattro Audi A4 Audi Avant Owner Group S-line owners group Manual
    5,964
    2,968
    or you could just buy the 2 switches from a seat dealer as the seat exeo has the silver edged switches on a rebadged 3 spoke s-line steering wheel, cost is a fraction of the same audi part.
  30. Ewan Hoozarmi
    Ewan Hoozarmi New Member
    I have just done the same mod, with the exact same style of wheel!
    Having had a 3 series previously, I never liked the fact that my B7 Avant SE didn't have an S-Line badge on the wheel. So, after much umming and erring, I took the plunge and bought a B8 MSFW from a company on Ebay, had the cruise retrofit done and even bought a replacement handbrake cover to match the two-tone grey leather in the car too. I now love my Audi even more - if that's possible!
    My previous MFSW is for sale. It's a DTM version if anyone is interested? The alcantara is more like regular leather now, but it's still in good condition.
