B8 S4 Oil consumption
S4 Phantom May 8, 2013
  1. S4 Phantom
    S4 Phantom Member
    32
    I have been reading so much about the oil consumption. Mine is running buring very little compare to most people, several thousands miles for half a litre if not less. Should I be worry that the MMI not reading correctly or I should call myself lucky!?!?
  2. Shadowman
    Shadowman Active Member
    592
    43
    Mine didn't use much...it depends how it's been run in, but don't trust the MMI as mine had a mind of its own.
    You can buy a dipstick from ECS (I think) which is a straight replacement for the plastic plug which comes as standard and means you can check your oil the old fashioned way !
  3. Spr0cket
    Spr0cket Member
    114
    Dipstick via local dealer, think mine was 8 quid.
  4. s4tronic
    s4tronic New Member
    23
    How easy it is to fit dip stick? Any guide available?
  5. riggssuzuki
    riggssuzuki Active Member
    496
    57
    As easy as remove the black plastic cap and stick in the dipstick in its place.
