Thinking of replacing the discs and pads as eurocarparts have 60% off tonight....
Discs seem to come in 2 options:
Brake Disc Thickness [mm]29,5
Brake Disc TypeVented
Centering Diameter [mm]68
Diameter [mm]345
Height [mm]52
Hole Arrangement / Number05/06
Minimum Thickness [mm]28
Pitch Circle Ø [mm]112
Weight [kg]10,8
Date To06/2011
Fitting PositionFront
Fitted Quantity2
PR Number1LJ
Other InformationDiameter 345mm
or
Brake Disc Thickness [mm]30
Diameter [mm]345
Height [mm]52
Weight [kg]11,1
Date From06/2011
Fitting PositionFront Axle
Fitted Quantity2
PR Number1LJ
Anyone know if this is correct or ECP doing something strange here?
Brembo discs and pads £212 down to £130 seems a bit of a bargain though
Diameter [mm]345
Height [mm]52
Weight [kg]10,8
Date To06/2011
Fitted Quantity2
PR Number1LJ
or
Diameter [mm]345
Height [mm]52
Weight [kg]11,1
Date From06/2011
Fitted Quantity2
PR Number1LJ
