b8 2.o tdi fuel filter location
marv Jul 1, 2012
  1. marv
    marv Member
    272
    hi serviced the car today but could i hell find the fuel filter, anyone know where it is, do they have one?
  2. andyarchery
    andyarchery New Member
    9
    Fuel filter is located under the car by the drivers door. Requires removal of a couple of plastic panels which is a real pain.
    Also note that the filter must be primed with fuel before starting the engine. You can do this by activating the fuel pump (insert key) before attaching the front fuel line.
  3. marv
    marv Member
    272
    thanks fella i will change this atr the weekend
  4. vw754
    vw754 vorsprung Durch Technik
    2,345
    58
    u ever get this done?.............whats the in and outs?
  5. Kalashnikov
    Kalashnikov Active Member
    231
    44
    any joy?
  6. Point_Audi
    Point_Audi Vorsprung durch Technik Staff Member Moderator VCDS Map User Gold Supporter Team Tornado Audi A5 Black Edition S-line owners group
    1,389
    975
    I changed my fuel filter a few months back, really handy done!:)
  7. Kalashnikov
    231
    44
    Any pictures or guides from elsawin
  8. Point_Audi
    1,389
    975
    I have a few pictures on the computer, but as mentioned above there is a cover under the drivers side, remove it and you will see the filter. One pipe in and one out!:) I done mine in an hour between stripping priming with VCDS and refitting!:)
  9. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User quattro Audi A4 Audi Avant Owner Group TDi
    5,739
    2,604
    The Fuel system is bled with VCDS , Air in the system may mean the high pressure pump will be running without lubrication for several seconds also the engine is liable to stall.
    ruairi83 and Kalashnikov like this.
  10. Kalashnikov
    231
    44
    This is really good. How do I go about getting access to elsawin
  11. Zafi
    Zafi Well-Known Member
    1,282
    320
    Links to hooky Elsawin sites are very shortlived ;)
  12. spartacus 68
    spartacus 68 Active Member quattro Audi A2 Audi Avant Owner Group
    377
    58
    Just away to do this on my Allroad this weekend as it'll be the first service I've done on this particular model. Why on earth do Audi install these daft fuel filters in a difficult to reach location that will undoubtedly leak when detached? There's plenty room in the engine bay and the conventional fuel filter can be filled with diesel rather than having to cycle the fuel pump with VCDS.
    Anyway, moan over. Purchased VCDS a few weeks ago as the rear electric parking brake needs to be activated with VCDS to check pads, so thought I might as well get it considering it's computer dependant.
