B7 to B6 Rear Lights coding, step by step instructions needed please
fullbor3 Mar 22, 2011
  1. fullbor3
    fullbor3 1st Gear
    37
    Hi
    Can any one help with step by step instructions on Vagcom coding needed to make b7 cab rear lights work in b6 cab with the adapters.
  2. Woorlord
    Woorlord shifting to Hyperspace... . VCDS Map User
    951
    Maybe here or here - always the best place to start with respects to any Coding.
    Will your current B6 Power Control Module be compatible with newer B7 features?
  3. fullbor3
    fullbor3 1st Gear
    37
    I hope so,i dont see why not as others have done this mod with success
  4. Woorlord
    951
    Out of curiosity why did they have to recode any modules?
    Would of thought the wiring adapters would be enough.
    Let us know how you get on.
  5. CHRIS555
    CHRIS555 DOPE with added OCD
    1,970
    10
    Speak to PJMSpeedy - he's done it with his - I've seen his and they look awesome and I will definately be doing mine in the next month or so for sure.
  6. fullbor3
    fullbor3 1st Gear
    37
    Your Right the adapters i bought from www.bks-tuning.com product#AUA4LO21,Worked without coding,result. Cost me 65 euro`s/ £57 for the 2 delivered.:o.k:
  7. hades-
    9,481
    646
    was gonna say you dont need to code them they are plug and play
    apart from wireing the second fog light in
  8. 1wheelonly
    1wheelonly cabriolet VCDS Map User
    2,385
    111
    They do require coding !!!
    You will find that they work ok with the loom adaptors but the light up of the rears is incorrect
    Only the square in the middle should be lit, you will find that on yours now that the middle square and the strip above will be dimly lit
    The top section is for brake lights only on the b7 rears
    And also there is only one fog light on the b7 rears
  9. fullbor3
    fullbor3 1st Gear
    37
    ok...........can u do a pic so i can get me head around it i.e b4 and after if poss.ta ?
  10. fullbor3
    fullbor3 1st Gear
    37
    or i do my b4 pic and u do ur after pic ?
  11. CHRIS555
    1,970
    10
    Ditto - they defo need coding! You will need to find someone who has VAG.COM and knows how to use it properly
  12. itsmeagain
    itsmeagain 1.8T Sport Cabriolet
    434
    I have been looking at mine recently, never actually checked them at night as I am always driving it. But I let my mate drive it a few days ago and I noticed that I too have the issue of the top light still being illuminated. When it should only be the square in the middle of the light that is lit up. Can anyone help??
  13. Woorlord
    951
    Out of curiosity the correct coding for this retrofit is?
    This may help a non-cab VCDS person help a cabby owner without VCDS.
  14. 1wheelonly
    2,385
    111
    cant remember the channel numbers,
    i think its central electrics, channel 002, not done it for a while but iyou need to find it in the brake light dimming
    it only shows saloon and avant,
    it will show 25%, this has to be set to 0% now
    the reason for this is due to the b6 having the rear lights as driving lights and brake lights combined ( getting brighter when braking )
    the b7 rears are independant, therefore no need for the top section to be lit ( now the centre square is lit ) top is brake lights only, now set to 0% and going to 100% when braking
  15. fullbor3
    fullbor3 1st Gear
    37
    Excellent info, just need to get Quattrojames on the case,as he has offered to have a go,but if anyone else in the dorset area wanna give me a hand it will be very much appreciated ?
  16. quattrojames
    14,050
    577
    Your trust in me is flattering!
  17. itsmeagain
    434
    Got mine coded today, took a few seconds. Now my lights look like they are supposed to.;);););)
  18. fullbor3
    fullbor3 1st Gear
    37
    :anbet:Sorry,didnt mean to poo poo your help,its just a comment made here,to get some one that knows vagcom etc
  19. Alan Westley
    Alan Westley New Member
    Hi 1Wheelonly I have a B6 cabby and a pair of B7 rear lights can you do mine and will I need the adapters also.
    Have you a contact number? mine is 07976469403 Alan
  20. variosso
    variosso Vorsprung Durch Technik
    358
    65
    Hi, not so sure if there is any coding needed as it should work with a bit of rewiring. Have a look on the wiring diagrams for B6 and B7 below. Hope that helps.
  21. hades-
    9,481
    646
    hes after the back light info
  22. variosso
    358
    65
    Thanks hades. My bad, it's a different thread I wanted to add it to. Someone was looking for some info on rewiring so I thought diagram will help. Thanks for pointing it out.
