B7 S-Line Cabriolet Rear diffuser
del14 Sep 26, 2012
  1. del14
    del14 New Member
    20
    Hi All just wondering if anyone knew where I can pick up a rear diffuser for s-line cab? Trying to stay away from the dealer at the moment...
    Del
  2. Joe_Murphy21187
    Joe_Murphy21187 S-Tronic
    1,064
    71
    eBay. Cab rear is the same as avant/saloon so any should fit providing it has the right exhaust cut outs.
  3. del14
    del14 New Member
    20
    cheers JJ, wasn't aware of that..!should make life a lot more straightforward.. Have been search for cabriolet only and they hardly come up if ever at all!!
  4. hades-
    9,481
    646
    are you sure the saloon avant fits the cab cos when i was at audi
    the cab 1 had a diffrent part number from the saloon avant
  5. Joe_Murphy21187
    1,064
    71
    As far I was aware it was only the front bumper that was slightly different? (still not sure how or why?)
    I was pretty sure the rear was the same, but if they're different, Bez is probably more equipped to answer 100%. Why did they bother to make cab parts different to the saloon/avant?
    While we're on the subject, are the cab headlights any different to the saloon/avant? And if so in what way? Want some new headlight units but a lot say 'not suitable for cabriolet', when they look the same??
  6. Joners
    Joners New Member
    if that is the case, this is a long shot but is the cab b7's front grille the same as the s-line avant? i want a black one..
  7. hades-
    9,481
    646
    all depends on
    have you got the SE bumper on your cab ? most B7 cabs came with the SE bumper even tho its a s-line model
    post a pic and ill tell you what you have.
  8. hades-
    9,481
    646
    iv fitted a DTM front bumper to a B7 cab and its a stright fit
    so the s-line should be a direct fit
    the head lights are the same as saloon avant and direct fit
    no idea why they messed about with the parts same as most s-line's came with the SE front bumper most late cabs came with the s-line.
