B7 Rear Lights Variations
A4_MaJiK Dec 11, 2012
  1. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    Anybody know if there is any variations between the B7 rear lights i.e. SE vs S-Line?
    I'm looking for a right rear replacement for my S-Line saloon as its tinted (for some strange reason) and don't want to end up getting the wrong part.
    Thanks in advance,
    Azeem.
  2. Joe_Murphy21187
    Joe_Murphy21187 S-Tronic
    1,064
    71
    I don't think so... but then that's not the most helpful comment :think:
  3. Rastamouse
    Rastamouse Welsh Audi Nut
    398
    19
    Im sure if read somewhere that avant and saloon rear lights are a different size to each other.but dont quote me on that tho!
  4. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    Yes, this is correct. Saloon, Avant and Cabriolet lights are all different from one another. I was mainly concerned about variations within these i.e. S-Line vs SE vs Sport etc.
  5. claudefrog
    claudefrog Member
    372
    This happened to me on a previous vag group car, turns out the light was not fully sealed and the diesel soot was getting into the light making it dark as if I tinted the lens.
    I removed it, soaked it in a basin with hot water and ssome alloy wheel cleaner for an hour then left it to dry, then put some superglue around the seal and it gave no trouble after that.
  6. Joe_Murphy21187
    1,064
    71
  7. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    Do you mean the seal around the light lens or the seal between the light and the body? Seems strange for something like this to happen but I suppose it could well be worth a shot.
    Thanks! :thumbsup:
  8. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
  9. claudefrog
    claudefrog Member
    372
    it was the seal where the lens is glued to the back housing of the light, if you remove the tail lamp completely and look at the plastic join you might be able to see a gap, how I found where it was leaking was when i lifted it out of the basin of water and the water run out of the lamp where it was not sealed correctly, would also explain the small flies that ended up in the light also.
