B7 Cab with 19" Alloys
Steve77 May 30, 2013
  1. Steve77
    Steve77 Member
    70
    Guys, am looking for some help and info if possible.
    Any cab owners with 19" alloys?
    can you let me know your wheel width, offset and tyre size please?
    I've just booth some 8.5, 19" with 43 offset and 255/35 tyres.
    But they touch the suspension bar at the top part of the arch when I lower the car down!
    Audi say this size should be ok!
  2. jimbooboo
    jimbooboo Member
    153
    9
    I was just thinking the exact same thing. Would like to see pics if poss.
    Cheers, James
  3. TOM.S
    TOM.S Active Member Silver Supporter
    564
    not a cab owner ,but I think its touching (if that's the case) because of the width of the tyre.
    255 is too much 19 tyres normally go by 235.
  4. hades-
    9,482
    646
    19" 8-1/2 235 35 19
    45 with 15mm spacers front 10mm back
    no rubbing
    [​IMG][​IMG]
  5. ctrsam
    ctrsam Member
    45
    10
    19x8.5 all round 235/35's all round et45 with 5mm spacers
  6. Abb
    Abb Member
    309
    Gents, I am running 19's on my S4 cab. They were et60 before I put 25mm spacer/adapters due to the pcd being 5x130, wearing 235/35/19 rubber. Has been lowered by approx 30mm using H&R springs, with no probs at all. Prior to these wheels, I was running speedlines with same suspension set up with no probs. I believe the exact offset to make the wheel sit flush with the arch is 35, am sure some one will be along soon and put me right, if that's wrong. Hope that helps.
  7. Boombastik
    Boombastik Member
    125
    13
    Bez
    What wheels are they ?
  8. hades-
    9,482
    646
    28 offset with a 235 35 is perfect with no rub
  9. Abb
    Abb Member
    309
    always rely on your fountain of knowledge to keep me right! :hi:
  10. Steve77
    Steve77 Member
    70
    So it seems like the 255's are just too wide. Great....NOT!
  11. Joe_Murphy21187
    Joe_Murphy21187 S-Tronic
    1,064
    71
    I've got 19" 8.5j, 235/35/19 tyres, ET45 with 12mm spacers so ET33. No rubbing at all.
    I would have to guess it's the tyres too...
  12. Steve77
    Steve77 Member
    70
    Thanks guys.
    Really I've got three options.
    Change the tyres to 235's and try and sell my old ones.
    Buy 10mm spacers and hope it doesn't push the wheels out too far.
    Sell them and buy a different set.
  13. A4Ade
    A4Ade Active Member
    106
    Dont forget its not just the width - 255/35 have a taller sidewall than 235/35 - overall, on 18" rims, you are looking at 635mm total diameter on 255/35 vs. 621mm on 235/35, so an extra ~1.5 cm of diameter on the wheels.
  14. Steve77
    Steve77 Member
    70
    Well I finally made the decision to add 5mm spaces on the front for now. And I'll replace the tyres will 235's down the line.
    Pretty happy with the look of the car now though!
